Hi Zen,
When using the +r option, all variables are part of a structure. Use the
pointer "pVar" to access them, for example:
pVar-> foo
This is described in the SNL manual in the section on syntax (Section 5,
pg 20 in rev 1.9).
Erik
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
> Sent: Monday, October 20, 2008 11:06 AM
> To: EPICS Techtalk
> Subject: Difficulties with my Sequencer program
> I am using seq-R2-0-11 and vxWorks 6.6.
> I have written a simple sequencer program, which monitors a
> PV and when the epics record processes, it saves the data
> from the PV to a disk file. The data written to disk is an
> ascii coded string, which contains configuration data for a
> VME module. All of this works flawlessly with one module.
> I have a few such modules and I want to keep the
> configuration data in separate files, so this is what I tried:
> 1. I have coded my sequencer program such that I pass to it
> information using a macro, which is used to select which PV
> to monitor and get data from and what file name to use.
> 2. I start a few instances of the same program, one for each module.
> I realized that this does not work. Looking at the manual
> for clues I see that the program must be made reentrant.
> Hence, I added option +r; to my program, but now it does not
> compile. Here are some details:
> In the program I have a few routines written in C coded as
> escaped to C. In the declaration part of the program I
> define a few variables, e.g. int update;. With the option +r;
> statement added, the C escaped routines no longer have access
> to the variables declared in the declaration part. I get a
> number of error messages like:
> "../sncFFF.st:120: error: 'update' undeclared (first use in
> this function)"
> When I examine the sncFFF.c code generated with the +r option
> and without, I do not see any significant difference.
> I am stuck now and any help or suggestions will be greatly
> appreciated.
> Zen
- Difficulties with my Sequencer program Szalata, Zenon M.
RE: Difficulties with my Sequencer program Mark Rivers
ioc reading data from files Pierrick Hanlet
<2008>
2025
2026
<2008>
2025
2026
