1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS Threading Issues
Date: Tue, 21 Oct 2008 16:29:43 -0700
Thanks for the help. After a quick test, the issue was that I was not properly using ca_attach_context.
This solved my problems.
-Richard
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Tuesday, October 21, 2008 4:21 PM
> To: Richard Pastrick; [email protected]
> Hello Richard,
> First, it is essential to be aware of the following synchronization
> fundamentals when using the CA client library. Additional details are in
> the
> manual (http://www.aps.anl.gov/epics/base/R3-14/8-docs/CAref.html).
> 1) One must either wait for successful connection callback, or for
> ca_pend_io to return success before using one or more channels that has
> been
> recently created. Persistent (long life span) applications really have no
> choice other than to wait for successful connection callback before using
> a
> channel considering that the channel connections are transient (ca
> channels
> can change in-between connected and disconnected states at any time).
> 2) After issuing one or more ca get request, one must call ca_pend_io to
> block for synchronization with the values being returned to your data
> buffers. For robustly implemented applications a better choice is to issue
> a
> ca get callback request.
> 3) The ca client library operates, depending on the developer's
> configuration, in one of two modes - preemptive and non-preemptive
> callback
> modes. Multithreaded applications typically use preemptive callback mode,
> but developers of multithreaded applications needs to know how to use a
> mutex to synchronize multiple asynchronous accesses to their data
> structures
> (originating from multiple threads).
> 4) Additional auxiliary threads that the developer spawns must take action
> to join with the CA context created in the primary thread (see
> ca_attach_context() in the manual).
> Second, due to the way the database is implemented, when the CA server
> executes a ca get request it does not cause the motor record to process.
> So
> what you will receive in the get response will only be a snapshot of the
> record's field at the instant in time when the ca get request is executed
> by
> the server. It's probably safe to say that the motor record is a bit more
> complex in the continuous asynchronous maintenance of its fields,
> occurring
> as the motor moves and otherwise changes state, compared to the typical
> EPICS record. It might be simpler and more robust to install a CA
> subscription (a ca monitor) if there is a need to continuously update the
> GUI that you are developing based on the state of a motor record's field.
> HTH,
> Jeff
> > From: [email protected] [mailto:tech-talk-
> [email protected]]
> > On Behalf Of Richard Pastrick
> > Sent: Tuesday, October 21, 2008 4:26 PM
> > To: [email protected]
> > Subject: EPICS Threading Issues
> > I have some questions regarding EPICS and threading. Let me start by
> laying
> > out the development environment.
> > I am developing an interface to an EPICS motor record using the CA API.
> I
> > am using base 3.14.8.2. I am compiling under windows using Visual Studio
> > 2008. I have successfully compiled all necessary components this way. I
> > know that there are no issues with the compiling because all of the
> > utilities and executables generated by the base are functional.
> > My interface is being generated in a GUI application for windows. When I
> > start the program, the main process thread instantiates a class which
> > contains all of my EPICS related code. This class will connect to the
> > various PVs I require and store their chid objects for future access.
> > I then go on to do other necessary steps for my program and eventually I
> > complete startup. Once startup has completed, there is a spawned thread
> > which will go to my EPICS class at a specified interval and retrieve new
> > data from the EPICS motors. These ca_get commands will fail to return
> any
> > accurate data. The return code they return indicates a success but the
> > data, as confirmed by both the caget utility and an MEDM window, is
> > incorrect. For example, if I have moved the motor to a position of 2.5,
> > both the MEDM window and caget will confirm that the RBV for that motor
> is
> > 2.5. My program will say that it is at 0.
> > If I issue a ca_get right after I create the channels in the same thread
> > that created the channels, I will receive the proper value of 2.5. I can
> > also use ca_put with no problem. So if I issue a command to move to 4.2
> > from my program, the motor actually will move to this new location but
> the
> > ca_get to retrieve the RBV will return 0 for the read value.
> > So my question boils down to this, should EPICS be able use a channel
> that
> > was created in a different thread?
> > Thank you,
> > Richard Pastrick
> > Associate Software Engineer
> > Xradia Inc
> > 5052 Commercial Cir
> > Concord CA 94520
> > 925-288-1228 Ext 1151
> > 925-348-0384 (cell)
RE: EPICS Threading Issues Jeff Hill
Prev: RE: EPICS Threading Issues Jeff Hill
Next: Re: ioc reading data from files Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Finding all the PVs on an IOC Carl Schumann
