1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MVME6100 or 7100
To: Kate Feng <[email protected]>
Cc: [email protected]
Date: Sun, 02 Nov 2008 07:44:06 -0800
I have used the MVME6100 with both vxWorks 5.5.1 and also vxWorks 6.6 with no problems.
By the way WindRiver does indeed supply a BSP for the MVME7100 under vxWorks 5.5.1 as well as vxWorks 6.6.
Ernest
Kate Feng wrote:
Hi Matt,
What is your application for the mvme6100 ?
At NSLS, I developed the "disco" BSP for RTEMS 4.8, which was
derived from the RTEMS-mvme5500 BSP to support the "discovery"
based boards such as the mvme5500 and mvme6100.  The BSP
works fine except the mvme6100 is not powerful enough to handle
the fast data rate of one of my applications.
I got impression from other users that the performance on the
vxWorks/mvme6100 is similar to that on RTEMS/mvme6100.  Thus,
I needed to choose a modern and cost-effective solution instead.
Hope this helps. Kate
Matt Rippa wrote:
Matt Rippa wrote:
Hi All -
Are any sites using the MVME6100 on VxWorks 5.5.2/Tornado 2.2.1? If so, would you recommend these?
Has anyone considered the new MVME7100 board? I'm not sure on the state of the BSP.
-Matt
Re: MVME6100 or 7100 Kate Feng
Prev: Re: MVME6100 or 7100 Kate Feng
Next: Re: MVME6100 or 7100 Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
