Following the thread base-3.14.10: libcurses vs. libncurses <http://www.aps.anl.gov/epics/tech-talk/2008/msg01196.php> I said Knowing that I could redefine it with an additional, local, site-specific CONFIG.... file So I tried to implement a file os/CONFIG_SITE.Common.linuxCommon containing the Site specific changes and believing the header of the os/CONFIG.Common.linuxCommon file: but it turned out that the CONFIG_SITE file was never called.# Definitions for linux target builds # Sites may override these definitions in CONFIG_SITE.Common.linuxCommon So my question is, would it make sense to follow the strategy used in
os/CONFIG.Common.{UnixCommon,RTEMS, vxWorksCommon}
to add in general at os/CONFIG.Common.linuxCommon's end the following lines?
In my case this turned out to work.#-------------------------------------------------- # Allow site overrides -include $(CONFIG)/os/CONFIG_SITE.Common.linuxCommon -include $(CONFIG)/os/CONFIG_SITE.$(EPICS_HOST_ARCH).linuxCommon I am actually not sure whether the second include is also needed, but it would make sense. Best regards, Peter -- Dr. rer. nat. Peter W. Zumbruch EE - department / Controls group / GSI E-Mail: P.Zumbruch_at_gsi.de Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986 Gesellschaft für Schwerionenforschung mbH Planckstraße 1 / D-64291 Darmstadt / www.gsi.de Gesellschaft mit beschränkter Haftung Sitz der Gesellschaft: Darmstadt Handelsregister: Amtsgericht Darmstadt, HRB 1528 Geschäftsführer: Professor Dr. Horst Stöcker Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph, Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
