1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC to use time from its own processor
Cc: [email protected]
Date: Thu, 06 Nov 2008 13:51:26 -0600
Hi Andrew,
Thanks much.  Now I get a lot of:
... recGblGetTimeStamp failed
It seems the recGblGetTimeStamp method is trying to check
the timestamp event, which we don't have.
Any idea?
Best regards,
Dehong
----- Original Message -----
Date: Thursday, November 6, 2008 10:54 am
To: Dehong Zhang <[email protected]>
> Hi Dehong,
> On Thursday 06 November 2008 09:53:43 Dehong Zhang wrote:
> > I made up a method like:
> > #include "epicsTime.h"
> > epicsTime getCurrent()
> >     struct timespec ts;
> >     clock_gettime( CLOCK_REALTIME, &ts );
> >     return epicsTime ( ts );
> The getCurrent routine needs to take a pointer to an epicsTimeStamp
> object,
> and it returns ERROR = -1 or OK = 0.  Try this:
> int clockGetCurrent (epicsTimeStamp *pDest) {
>     struct timespec ts;
>     if (clock_gettime (CLOCK_REALTIME, &ts))
>         return -1;
>     *pDest = epicsTime (ts);
>     return 0;
> > Can i invoke iocClockRegister(&getCurrent, NULL) in the vxWorks
> > startup script (how ?), or I have to wrap it with a simple command
> so that
> > it can be invoked before iocInit?
> For R3.14.8 I think you should be able to put that statement directly
> in your
> startup script; replace the NULL with 0 though, and make sure you call
> it
> before any EPICS code runs that asks for the current time since that
> will
> cause the built-in routines to get registered instead.  It's possible
> that
> you might have to drop the ampersand & character, but try it with first.
> HTH,
> - Andrew
> Talk is cheap. Show me the code. -- Linus Torvalds
Re: IOC to use time from its own processor Andrew Johnson
IOC to use time from its own processor Dehong Zhang
Re: IOC to use time from its own processor Dehong Zhang
Prev: Re: IOC to use time from its own processor Andrew Johnson
Next: Re: IOC to use time from its own processor Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
