1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C++ and genSubRecord.h
To: Pierrick Hanlet <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 11 Nov 2008 10:42:16 -0600
Without changing the field names I don't see how C++ is going to work.
The line in question is:
	 epicsUInt32 not; /* No. in T */
And 'not' is a C++ keyword.
On Nov 11, 2008, at 10:34 AM, Pierrick Hanlet wrote:
I have a problem with genSubRecord.h when compiling my code as
C++ source instead of C. I've stripped everything out of the code,
except for header files, and empty functions and called the source file
either "test.c" or "test.cc". In my source directory, I've modified the
Makefile to use the source test.c or test.cc (I've also deleted the other
source file in the directory).
When the Makefile uses test.c, there are no compilation errors.
However, when the Makefile uses test.cc, then I get the following
compilation errors:
../../include -I/usr/local/epics/base/include/os/Linux -I/usr/local/ epics/base/include ../test.cc
../../../include/genSubRecord.h:185: error: expected unqualified-id before ‘!’ token
make[3]: *** [test.o] Error 1
make[3]: Leaving directory `/home/hanlet/epics/tgtMon/tgtMonApp/src/ O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/hanlet/epics/tgtMon/tgtMonApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/hanlet/epics/tgtMon/tgtMonApp'
make: *** [tgtMonApp.install] Error 2
Any ideas on how to proceed?
Pierrick
----------------------------------------------------------------------------------------- Pierrick Hanlet Fermilab, P.O. Box 500, M.S. 122 Batavia, IL 60510 [email protected] (630)840-5555/8871/6039 office/lab/fax http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
C++ and genSubRecord.h Pierrick Hanlet
Prev: C++ and genSubRecord.h Pierrick Hanlet
Next: Re: C++ and genSubRecord.h Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
