1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: WireSet missing with 3.14.10
Cc: [email protected]
Date: Wed, 12 Nov 2008 16:30:39 -0600
Hi Andrew,
Sorry my original question was not very clear.
I am trying to upgrade from epics 3.14.8 to 3.14.10.  My vxworks is v6.1.
The epics base and my application were both built fine, no complaints.  But
when i load the munch file, it complains about ... undefined.
I then ran the c++filt like you suggested, and found the missing method is
called "WireSet", which should have been defined in include/osiWireFormat.h
Later in tech-talk I found that someone compalined about exactly the same
problem.  And there was a suggestion to "make sure you build iocCoreLibrary"
with the base, and add the library in the make file.
I am having a hard time to find out how to force to build iocCoreLibrary.
There is no mentioning of it in any document.  Any idea?
Thanks much, best regards,
Dehong
----- Original Message -----
Date: Wednesday, November 12, 2008 4:06 pm
To: [email protected]
Cc: Dehong Zhang <[email protected]>
> On Wednesday 12 November 2008 13:02:17 Dehong Zhang wrote:
> > I am trying to upgrade to 3.14.10.  Succeeded on building epics base
> > and my application.  When I try to load the munch file to vxWorks, it
> > complains about undefined symbol "WireSet" etc.  Please advice.
> 3.14.10 works fine on vxWorks for me.
> That answer wasn't very helpful to you, but your question was too
> vague for
> any better response.  Please post the exact error message you see, and
> the
> target architecture and version of vxWorks that you're using (and
> remember
> that advice for the future too).  If the symbol names reported have
> been
> mangled by the C++ compiler, please attempt to de-mangle them by
> passing them
> through the version of c++filt that is in the same directory as the compiler.
>     http://www.catb.org/~esr/faqs/smart-questions.html
> - Andrew
> Talk is cheap. Show me the code. -- Linus Torvalds
Re: WireSet missing with 3.14.10 Andrew Johnson
WireSet missing with 3.14.10 Dehong Zhang
Prev: Re: WireSet missing with 3.14.10 Andrew Johnson
Next: Re: WireSet missing with 3.14.10 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
