1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC Shell
To: David Dudley <[email protected]>
Date: Wed, 19 Nov 2008 15:13:00 -0600
On Nov 19, 2008, at 2:55 PM, David Dudley wrote:
Where does the IOC shell come from?
The source is in <base>/src/libCom/iocsh/
I'm working with NetBSD, and when I generate an IOC, the shell I get doesn't handle command history, or arrow commands.
There are three possible input mechanisms. The selection is made by the build system COMMANDLINE_LIBRARY value, which may be EPICS (the simplest in that it needs no additional external libraries, but provides no command-line editing or history), READLINE (which uses the GNU readline library), or TECLA (which uses the tecla library). Have a look in <base>/configure/os/ for some examples.
Am I missing a library (like GNUreadLine)?
David
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
IOC Shell David Dudley
Prev: IOC Shell David Dudley
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: A db question about aiExample marco_hair
