1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building system with Debug
To: [email protected]
Date: Wed, 19 Nov 2008 17:13:33 -0600
On Tuesday 18 November 2008 11:34:10 David Dudley wrote:
> Is there a predefined method of generating a system that contains 'debug'
> labels and source line references?
For R3.14.10 Janet added -debug versions of many of the target architectures,
so for example you can cross-build the linux-x86-debug target on a linux-x86
host and you'll be able to run either the regular or the debug version of
your code.  Alternatively set your EPICS_HOST_ARCH to linux-x86-debug and
just build and use that normally.
> I see in the configure files that there is a variable called
> 'OPT_CFLAGS_YES' and 'OPT_CFLAGS_NO", but don't see any way to use them.
The variables HOST_OPT and CROSS_OPT control which one gets used; set them to
YES or NO in your configure/CONFIG_SITE or configure/os/CONFIG_SITE.*.* files
as appropriate.
HTH,
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Building system with Debug David Dudley
Prev: Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Next: Re: caPutLogging Documentation Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Building system with Debug David Dudley
Next: priority callback tasks Kevin Tsubota
