1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: A db question about aiExample
To: "tech-talk" <[email protected]>
Date: Sun, 23 Nov 2008 11:15:57 +0800
hi, Ned Arnold:
  It does work! thanks for your reply and also powerful design of LA field.
======= At 2008-11-20, 22:50:01 you wrote: =======
>Geyang -
>Changing the definition of the calc record to this (only the CALC and
>INPB field are different) will give you the desired result:
>record(calc, "$(user):calcExample")
>         field(DESC, "Counter")
>         field(SCAN,"1 second")
>         field(FLNK, "$(user):aiExample")
>         field(CALC, "A-B>0?A=9?8:A+1:A=0?1:A-1")
>         field(INPA, "$(user):calcExample.VAL  NPP NMS")
>         field(INPB, "$(user):calcExample.LA NPP NMS")
>         field(EGU, "Counts")
>         field(HOPR, "10")
>         field(HIHI, "8")
>         field(HIGH, "6")
>         field(LOW, "4")
>         field(LOLO, "2")
>         field(HHSV, "MAJOR")
>         field(HSV, "MINOR")
>         field(LSV, "MINOR")
>         field(LLSV, "MAJOR")
>    Ned
>On Nov 20, 2008, at 4:57 AM, marco_hair wrote:
>> Dear all:
>>   in the aiExample.db coming with soft ioc template,
>> record(ai, "$(user):aiExample")
>> field(DESC, "Analog input")
>> field(INP, "$(user):calcExample.VAL  NPP NMS")
>> field(EGUF, "10")
>> field(HOPR, "10")
>> field(LOPR, "0")
>> field(HIHI, "8")
>> field(HIGH, "6")
>> field(LOW, "4")
>> field(LOLO, "2")
>> field(HSV, "MINOR")
>> field(LSV, "MINOR")
>> field(CALC, "(A<B)?(A+C):D")
>> field(INPB, "9")
>> field(INPC, "1")
>> field(INPD, "0")
>> field(HOPR, "10")
>> field(HIHI, "8")
>> field(HIGH, "6")
>> field(LOW, "4")
>> field(LOLO, "2")
>> field(HSV, "MINOR")
>> field(LSV, "MINOR")
>> the ai value will change from 0-9 and then loop from 0 again.
>> if I want to generate the value from 0-9, then decrease it, such as
>> 9-0. That is, the value increase from 0-9, then decrease from 9-0
>> one by one, how can I written it?
>> Thanks a lot for your help.
>> Best wishes
>> Geyang 2008/11/20
>> [广告] 金秋最关注楼盘-房不胜房
Best regards
Geyang 2008-11-23
A db question about aiExample marco_hair
Re: A db question about aiExample Ned Arnold
Prev: RE: solaris-x86 build error on 3.14.10 Mark Rivers
Next: Re: RE: RE: A db question about aiExample Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: A db question about aiExample Ned Arnold
