1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A bug of calc record?
To: [email protected]
Date: Sun, 23 Nov 2008 21:55:27 -0600
This is not actually a problem. 1.38777878078145e-16 is an excellent
approximation to the desired value of zero, and an excellent approximation
is the best you can ever hope for, with finite-precision arithmetic.
You're accumulating round-off error each time you add or subtract 0.1.
You could set PREC to, say, 6, and clients would only show 6 digits
of the result.  (I don't know right off if dbpr honors PREC, but it's
just a diagnostic routine, so it won't usually matter.)
Silver wrote:
> hi, all:
> I am trying to use the record suggested by Ned Arnold. It's good work when
> increment is 1. but when I change to 0.1, it has a strange problem. the db
> file is like following:
> record(ai, "$(user):aiExample") { field(DESC, "Analog input") field(INP,
> "$(user):calcExample.VAL  NPP NMS") } record(calc, "$(user):calcExample") {
> field(DESC, "Counter") field(SCAN,"1 second") field(FLNK,
> "$(user):aiExample") field(CALC, "A-B>0?A>=0.9?0.8:A+0.1:A<0.1?0.1:A-0.1")
> field(INPA, "$(user):calcExample.VAL  NPP NMS") field(INPB,
> "$(user):calcExample.LA NPP NMS") field(EGU, "Counts") }
> Following is dbtr message, we can see when the value change to 0.1, after
> caculation, it's value change to VAL: 1.38777878078145e-16, can anyone give
> some suggestion? thanks a lot in advance.
> epics> dbtr tcl:calcExample A: 0.2              ACKS: NO_ALARM      ACKT: YES
> ADEL: 0 ALST: 0.1           ASG:                B: 0.3              BKPT:
> 0x00 C: 0                CALC: A-B>0?A>=0.9?0.8:A+0.1:A<0.1?0.1:A-0.1
>  D: 0                DESC: Counter       DISA: 0             DISP: 0
>  DISS: NO_ALARM      DISV: 1             DTYP: <nil>         E: 0
>  EGU: Counts         EVNT: 0             F: 0 FLNK:DB_LINK tcl:aiExample
> G: 0                H: 0 HHSV: NO_ALARM      HIGH: 0             HIHI: 0
> HOPR: 0 HSV: NO_ALARM       HYST: 0             I: 0 INPA:DB_LINK
> tcl:calcExample.VAL NPP NMS INPB:DB_LINK tcl:calcExample.LA NPP NMS
> INPC:CONSTANT       INPD:CONSTANT INPE:CONSTANT       INPF:CONSTANT
> INPG:CONSTANT       INPH:CONSTANT INPI:CONSTANT       INPJ:CONSTANT
> INPK:CONSTANT       INPL:CONSTANT J: 0                K: 0                L:
> 0                LA: 0.2 LALM: 0.1           LB: 0.3             LC: 0
> LCNT: 0 LD: 0               LE: 0               LF: 0               LG: 0
>  LH: 0               LI: 0               LJ: 0               LK: 0
>  LL: 0               LLSV: NO_ALARM      LOLO: 0             LOPR: 0
>  LOW: 0              LSV: NO_ALARM       MDEL: 0             MLST: 0.1
>  NAME: tcl:calcExample                   NSEV: NO_ALARM      NSTA: NO_ALARM
>  PACT: 0             PHAS: 0             PINI: NO            PREC: 0
>  PRIO: LOW           PROC: 0             PUTF: 0             RPRO: 0
>  SCAN: 1 second      SDIS:CONSTANT       SEVR: NO_ALARM      STAT: NO_ALARM
>  TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 0
>  VAL: 0.1 epics> dbtr tcl:calcExample A: 0.1              ACKS: NO_ALARM
> ACKT: YES           ADEL: 0 ALST: 1.38777878078145e-16              ASG:
> B: 0.2 BKPT: 0x00          C: 0 CALC: A-B>0?A>=0.9?0.8:A+0.1:A<0.1?0.1:A-0.1
> D: 0 DESC: Counter       DISA: 0             DISP: 0             DISS:
> NO_ALARM DISV: 1             DTYP: <nil>         E: 0                EGU:
>  HIHI: 0             HOPR: 0             HSV: NO_ALARM       HYST: 0
>  I: 0                INPA:DB_LINK tcl:calcExample.VAL NPP NMS
>  INPB:DB_LINK tcl:calcExample.LA NPP NMS INPC:CONSTANT       INPD:CONSTANT
>  INPE:CONSTANT       INPF:CONSTANT       INPG:CONSTANT       INPH:CONSTANT
>  INPI:CONSTANT       INPJ:CONSTANT       INPK:CONSTANT       INPL:CONSTANT
>  J: 0                K: 0                L: 0                LA: 0.1
>  LALM: 1.38777878078145e-16              LB: 0.2             LC: 0
>  LG: 0               LH: 0               LI: 0               LJ: 0
>  LK: 0               LL: 0               LLSV: NO_ALARM      LOLO: 0
>  LOPR: 0             LOW: 0              LSV: NO_ALARM       MDEL: 0
>  MLST: 1.38777878078145e-16              NAME: tcl:calcExample
>  NSEV: NO_ALARM      NSTA: NO_ALARM      PACT: 0             PHAS: 0
>  PINI: NO            PREC: 0             PRIO: LOW           PROC: 0
>  PUTF: 0             RPRO: 0             SCAN: 1 second      SDIS:CONSTANT
>  SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0             TSE: 0
>  TSEL:CONSTANT       UDF: 0              VAL: 1.38777878078145e-16
>  epics> dbtr tcl:calcExample A: 1.38777878078145e-16                 ACKS:
> NO_ALARM      ACKT: YES ADEL: 0             ALST: 0.1           ASG:
> B: 0.1 BKPT: 0x00          C: 0 CALC: A-B>0?A>=0.9?0.8:A+0.1:A<0.1?0.1:A-0.1
>  J: 0                K: 0                L: 0 LA: 1.38777878078145e-16
> LALM: 0.1           LB: 0.1 LC: 0               LCNT: 0             LD: 0
> LE: 0 LF: 0               LG: 0               LH: 0               LI: 0
>  LJ: 0               LK: 0               LL: 0               LLSV: NO_ALARM
>  LOLO: 0             LOPR: 0             LOW: 0              LSV: NO_ALARM
>  MDEL: 0             MLST: 0.1           NAME: tcl:calcExample
>  TSEL:CONSTANT       UDF: 0              VAL: 0.1 epics>
> Best regards Geyang  2008-11-23
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: A bug of calc record? Dirk Zimoch
A bug of calc record? Silver
Prev: A bug of calc record? Silver
Next: Re: Working with sequencer Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: A bug of calc record? Dirk Zimoch
