1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: questions about stepper motor
To: <[email protected]>
Date: Wed, 26 Nov 2008 15:04:17 -0500
Hello,
I’m new to motor stepper and I’d like to ask some questions.
I’ve read the motor record and I’m not sure I can get what the HOMR, HOMF, JOGR, JOGF means. What are they used for?
I thought HOMR/HOMF has some relation with LLM/HLM respectively. Is that right? If is, what’s the relation? What about JOGF/JOGR?
In the motor record documentation, it says ‘these fields can be set to 1, but setting either field to 0 results in an error’. What kind of error it may cause? I found that in the IOC initialization, no values are set to these field, that means the default value 0 is used. And then when the HOMR or HOMF is clicked(motorx_all.adl), such error occurs:
Filename=”../devOmsCom.cc” line number=404
Overriding invalid velocity; slew<=base.
Even if the HOMF and HOMR are set to 1, the same error occurs. Thus I thought this error is not caused by the settings of HOMF and HOMR. I thought it was caused by the velocity is too slow even smaller than the base velocity. But I don’t know how to solve it. The motor and motion related fields are set as follows in my situation.
MRES=0.18         UREV=360           SREV=2000          VELO=20              S=0.0555556       VBAS=2
The MD125 microstep drive is used and the step rate is 10. I’d like to know how to solve this problem.
The above error will not affect the running of the motor. But when the JOGF/JOGR is used, a fatal error occurred.
FATAL: unrecoverable exception without a task context.
The error displayed on MEDM is:
Channel Access Exception:
Channel Name: Unavailable
Native Type: Unavailable
Native Count: 0
Access: Unavailable
Message: Virtual Circuit unresponsive
Context: 192.168.2.105:5064
Requested Type: TYPENOTCONN
Requested Count: 0
Source File: ../tcpiiu.cpp
Line Number: 921
The JOGF and JOGR are not set in initialization. The default value 0 are used. Even changed after initialization, the same error still occurs.
I will evaluate the performance of the stepper motor. When doing this, I want to keep the motor moving all the time for several months.  Is there anyone who did the similar thing before? I can’t find any reference to continuous motion. The files I was given had very little in the way of documentation. The http://www.aps.anl.gov/xfd/SoftDist/swBCDA/recMotor.html used to be the developer documentation. But I can’t find it now.
Is there anyone know? Thanks.
Huijuan
RE: questions about stepper motor Mark Rivers
Re: questions about stepper motor Kurt Goetze
Prev: Getting Sequencer installed in right paths David Dudley
Next: RE: questions about stepper motor Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
