1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: New CVS compiles failed on Windows
To: Zhichu Chen <[email protected]>
Cc: [email protected]
Date: Mon, 01 Dec 2008 10:43:13 -0600
I agree that users should take care of the $PATH environment variable
themselves. I will remove the PATH related lines from CONFIG_SITE.win32-x86-mingw.Common for the next base release. Thanks.
Janet
Zhichu Chen wrote:
I checked the EPICS site today and found a new cvs version for
download. This is my environment:
OS: Windows XP SP3
Compiler:
$ gcc -v
Using built-in specs.
Target: mingw32
Configured with: ../gcc-4.3.0/configure
--enable-languages=c,ada,c++,fortran,java,objc,obj-c++
--disable-sjlj-exceptions
 --enable-shared --enable-libgcj --enable-libgomp --with-dwarf2
--disable-win32-registry --enable-libstdcxx-debug --enab
le-concept-checks --enable-version-specific-runtime-libs
--build=mingw32 --with-bugurl=http://www.mingw.org/bugs.shtml -
-prefix=/mingw --with-gmp=/mingw/src/gcc/gmp-mpfr-root
--with-mpfr=/mingw/src/gcc/gmp-mpfr-root --with-libiconv-prefix=/
mingw/src/gcc/libiconv-root
Thread model: win32
gcc version 4.3.0 20080305 (alpha-testing) mingw-20080502 (GCC)
Environment: MSYS
$ echo $EPICS_HOST_ARCH
win32-x86-mingw
I was told that something error in src/libCom/osi/os/WIN32/osdTime.cpp.
I'm sorry, I can't remember exactly what the error message is, it's
pretty much like
"passing `volatile currentTime' as `this' argument of
`currentTime::startPLL' discards qualifiers"
I "fixed" it by modifying line 88:
static volatile currentTime * pCurrentTime = 0;
to
static currentTime * pCurrentTime = 0;
It compiles OK and runs fine, only that there're so many lines in the
sources and I
can't be sure this would be safe. Can you tell me what is the worst
thing that would
happen?
By the way, about the file
configure/os/CONFIG_SITE.win32-x86-mingw.Common, I really think one
should take care of their $PATH environment themselves, and not all
people would install their
gcc under C:/MinGW/bin. Not only it's not cool, but those lines made
my sh confused and messed
all the $PATH environment and even cannot find "make" itself.
New CVS compiles failed on Windows Zhichu Chen
Prev: Re: New CVS compiles failed on Windows Zhichu Chen
Next: Re: New CVS compiles failed on Windows Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: New CVS compiles failed on Windows Andrew Johnson
Next: Device Driver Initialization routine David Dudley
