Dirk, Thanks for the information. We have little choice, because the
code change must happen between 3.14.9 and 3.14.10. At minimum, the
fix communicates the solution. In the event it doesn't also implement
it, we rely on knowledgeable humans. I hate relying on humans, of course,
but I must admit that they are sometimes pretty handy things to have around.
By the way, Ron Sluiter was the guy who figured out how to do this. (He
loves being blamed for stuff.)
Tim
Dirk Zimoch wrote:
Hi Tim,
Arithmetic with macros like EPICS_MODIFICATION<(l) only works if
EPICS_MODIFICATION is numeric. This is not guaranteed. In pre-releases
like 3.14.10-pre1 we have:
# This part may contain letters, eg 0beta1
EPICS_MODIFICATION = 10pre1
Of course it would be nice to have a mechanism to find out the current
EPICS release, but EPICS does not provide this feature.
Dirk
Tim Mooney wrote:
John,
You can fix the scanOnce errors like this:
scanOnce((struct dbCommon *)psscan);
and the precision problem like this:
pPos->p_pr = precPvt->pDynLinkInfo->precision.dp;
But note that the precision fix is base-version dependent. The current
sscanRecord code actually looks like this:
#include <epicsVersion.h> /* for LT_EPICSBASE macro */
/* Less than EPICS base version test.*/
#define LT_EPICSBASE(v,r,l) ((EPICS_VERSION<=(v)) &&
(EPICS_REVISION<=(r)) && (EPICS_MODIFICATION<(l)))
#if LT_EPICSBASE(3,14,10)
pPos->p_pr = precPvt->pDynLinkInfo->precision;
#else
#endif
Tim
John M. Skinner wrote:
I'm trying to build sscan 2.6.2 on EPICS base 3.14.10 but get these
compile warnings and errors:
../sscanRecord.c: In function `special':
../sscanRecord.c:1451: warning: passing arg 1 of `scanOnce' from
incompatible pointer type
../sscanRecord.c:1585: warning: passing arg 1 of `scanOnce' from
../sscanRecord.c: In function `notifyCallback':
../sscanRecord.c:2457: warning: passing arg 1 of `scanOnce' from
../sscanRecord.c: In function `userGetCallback':
../sscanRecord.c:2523: warning: passing arg 1 of `scanOnce' from
../sscanRecord.c: In function `pvSearchCallback':
../sscanRecord.c:2613: error: incompatible types in assignment
../sscanRecord.c:2643: error: incompatible types in assignment
../sscanRecord.c:2743: warning: passing arg 1 of `scanOnce' from
../sscanRecord.c: In function `posMonCallback':
../sscanRecord.c:2818: warning: passing arg 1 of `scanOnce' from
../sscanRecord.c: In function `doPuts':
../sscanRecord.c:4013: warning: passing arg 1 of `scanOnce' from
../sscanRecord.c:4190: warning: passing arg 1 of `scanOnce' from
I get the same results on both Fedora Core 3 and Fedora Core 8. I
have no problem building the scan record on EPICS base 3.14.9.
thanks,
John Skinner (BNL/NSLS)
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
- sscan compile error on base 3.14.10 on linux John M. Skinner
- Re: sscan compile error on base 3.14.10 on linux Tim Mooney
- Re: sscan compile error on base 3.14.10 on linux Dirk Zimoch
Device Driver Initialization routine David Dudley
<2008>
2025
2026
Re: sscan compile error on base 3.14.10 on linux Andrew Johnson
<2008>
2025
2026
