1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to implement simple control algorithm
To: "Ilya V. Kitaev" <[email protected]>
Cc: [email protected]
Date: Wed, 3 Dec 2008 14:30:08 +0100
You do not need to write your own CA application for that.
Monitor alarm status of your "ai" with a "calcout" record and write to
your "bo" upon occurrence of the conditions.
This can be done for example as the following:
record(calcout, "$(ALGORITHM)")
        field(INPA,"$(YOUR_AI_REC).STAT CP") # monitoring
        field(INPB,"$(YOUR_BO_REC).VAL NPP")
        field(CALC, "A=3?1:A=5?0:B")
        field(OOPT, "On Change")
        field(OUT,"$(YOUR_BO_REC) PP")
Alarm status value for HIHI is 3 and for LOLO is 5.
HTH,
Babak
> -----Original Message-----
> From: [email protected]
[mailto:[email protected]]
> On Behalf Of Ilya V. Kitaev
> Sent: Mittwoch, 3. Dezember 2008 12:33
> To: [email protected]
> Subject: How to implement simple control algorithm
> Hello.
> Could anyone give me advice how to implement following control
> algorithm: I have IOC with two records, for instance, "ai" and "bo";
> ai record with periodic scan, "bo" with passive scan.  How do i turn
> on "bo" record when, for example, HIHI alarm on "ai" record triggered,
> and turn off when LOLO alarm on "ai" record triggered?
> Should i implement this as standalone Channel Access application,
> which will monitor "ai" record and force "bo" record, or it can be
> implemented by connecting records together(how, which records) in IOC
> database?
> Thanks.
Alarms vs. Interlocks Re: How to implement simple control algorithm Kasemir, Kay
How to implement simple control algorithm Ilya V. Kitaev
Prev: How to implement simple control algorithm Ilya V. Kitaev
Next: Alarms vs. Interlocks Re: How to implement simple control algorithm Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
