Hi John,
On Friday 19 December 2008 John Faucett wrote:
> The stringin record for EPICS 3.13.7 does not respond to a request
> for units (DBR_GR_SHORT).
> and then realized that 3.13.7 is the version of the client
> application. The IOC is running 3.13.4.
> After 3 seconds the request times out with
> CA.Client.Exception...............................................
> Warning: "Channel read request failed"
> Context: "op=0, channel=ABCDE, type=DBR_GR_SHORT, count=1,
> ctx="read failed""
> Source File: ../getCopy.cpp line 82
> Current Time: Mon Dec 19 2008 14:22:41.375447000
Your version number for the CA client still doesn't make sense, I think you
mean 3.14.7.
I just tried the following with 3.14.10 versions of the IOC and caget program,
which works just fine as long as the VAL field contains something that can be
converted into a short:
tux% caget -d DBR_GR_SHORT mrk:stringinsyn
mrk:stringinsyn
Data type: DBR_GR_SHORT (native: DBF_STRING)
Element count: 1
Value: 3
Status: NO_ALARM
Severity: NO_ALARM
Units:
Lo disp limit: 0
Hi disp limit: 0
Lo alarm limit: 0
Lo warn limit: 0
Hi warn limit: 0
Hi alarm limit: 0
However it I make the VAL field something non-numeric, I get your error
message:
tux% caput mrk:stringinsyn abcd
Old : mrk:stringinsyn 3
New : mrk:stringinsyn abcd
Context: "op=0, channel=mrk:stringinsyn, type=DBR_GR_SHORT, count=1,
ctx="read failed""
Source File: ../getCopy.cpp line 86
Current Time: Fri Dec 19 2008 17:10:15.490387940
Read operation timed out: some PV data was not read.
mrk:stringinsyn
Element count: 1
Value: 0
Status: NO_ALARM
Severity: NO_ALARM
Units:
Lo disp limit: 0
Hi disp limit: 0
Lo alarm limit: 0
Lo warn limit: 0
Hi warn limit: 0
Hi alarm limit: 0
That this fails is quite reasonable since I'm asking the IOC to convert the
string "abcd" into an integer; the issue is nothing to do with the fact that
the stringin record doesn't support units. I will admit that the error
message leaves a lot to be desired though; please complain to Jeff Hill about
that, it's his code generating the string.
Merry Christmas,
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- RE: Units request for stringin records Jeff Hill
- Units request for stringin records John Faucett
Re: Units request for stringin records John Faucett
<2008>
2025
2026
<2008>
2025
2026
