1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MAXvSetup is an undefined symbol
To: <[email protected]>, <[email protected]>
Date: Mon, 12 Jan 2009 13:08:36 -0000
Title: Message
Hello Wangqisheng,
Looking at your Makefile, you need to add the line:
mx_LIBS += oms
This is the OMS specific library from the motor support package and provides the MAXvSetup() function. Hopefully this will cure your unresolved reference.
Ian Gillingham
Diamond Light Source
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: 12 January 2009 11:43
To: [email protected]
Subject: MAXvSetup is an undefined symbol
Hello,everyone.
I have two application of oms motor and hytec adc, but i only have a VME crate. So i need to merget the two application to one ioc. The oms motor application from
synApps and hytec 8401 work well respectively. So i use the makeBaseApp.pl to produce a new application and revise the makefile, and copy the source file to the
corresponding directory. The compile is ok, i can get the munch and st.cmd files.
When download st.cmd to the vme, there are will problems. It is said the MAXvSetup is an undefined symbol. It is very strange. I insert the hytec8001 and 8401 in the
first and the VME in the third.
Please give me some advice and idea.
Thanks.
----------------------Makefile-----------------------------------------
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# build an ioc application
PROD_IOC_vxWorks = mx
DBD += mx.dbd
# mx.dbd will be made up from these files:
mx_DBD += base.dbd
#include definitions for any other support applications needed
#mx_DBD += xxx.dbd
mx_DBD += transformRecord.dbd
mx_DBD += oms.dbd
mx_DBD += motorSupport.dbd
mx_DBD += motorRecord.dbd
mx_DBD += devOms.dbd
mx_DBD += devSoftMotor.dbd
mx_DBD += PSU0.dbd
mx_DBD += sscan.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
mx_SRCS_vxWorks += mx_registerRecordDeviceDriver.cpp
mx_SRCS_DEFAULT += mxMain.cpp
mx_SRCS_vxWorks += -nil-
mx_SRCS_vxWorks += devOms.cc drvOms.cc
mx_SRCS_vxWorks += devOms58.cc drvOms58.cc
mx_SRCS_vxWorks += devMAXv.cc drvMAXv.cc
mx_SRCS_vxWorks += devOmsCom.cc
mx_SRCS_vxWorks += devSoft.cc devSoftAux.cc
mx_SRCS_vxWorks += motorRecord.cc motordevCom.cc motordrvCom.cc
#The following adds support from base/src/vxWorks
mx_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
#add a definition for each support application used by this application
#mx_LIBS += xxx
#NOTES:
#      1)It is not possible to build sncExample both as a component of mx
#        and standalone. You must choose only one.
#      2)To build sncExample SNCSEQ must be defined in <top>/configure/RELEASE
#The following builds sncExample as a component of mx
#mx_SRCS += sncExample.stt
#mx_LIBS += seq pv
mx_LIBS += motor
mx_LIBS += SoftMotor
mx_LIBS += Ipac
mx_LIBS += Hy8402ip
mx_LIBS += Hy8401ip
mx_LIBS += calc
mx_LIBS += sscan
mx_LIBS_vxWorks += $(EPICS_BASE_IOC_LIBS)
#The following builds sncExample as a standalone application
#PROD_HOST += sncExample
#sncExample_SNCFLAGS += +m
#sncExample_SRCS += sncExample.stt
#sncExample_LIBS += seq pv
#sncExample_LIBS += $(EPICS_BASE_HOST_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
-----------------------------Error mesg--------------------------------
ld < mx.munch
sysAtReboot not found. epicsExit will not be called by reboot.
value = 516036768 = 0x1ec218a0
cd top
value = 0 = 0x0
dbLoadDatabase("dbd/mx.dbd",0,0)
value = 0 = 0x0
mx_registerRecordDeviceDriver(pdbbase)
value = 0 = 0x0
## motor
dbLoadRecords("db/att.db")
value = 0 = 0x0
MAXvSetup(1,16,0xF000,180,6,10)
undefined symbol: MAXvSetup
汪启胜
No.239 Zhangheng Road
PuDong District
Shanghai Institute of Applied Physics CAS
Shanghai, China
Tel: +86-21-33933256  Fax: +86-21-33933031
Scanned by iCritical.
MAXvSetup is an undefined symbol 汪启胜
Prev: MAXvSetup is an undefined symbol 汪启胜
Next: Re: MAXvSetup is an undefined symbol Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
