1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AreaDetector, Compiling synApps modules for Windows Microsoft compiler
To: [email protected]
Cc: Timothy Madden <[email protected]>
Date: Mon, 12 Jan 2009 13:42:22 -0600
On Monday 12 January 2009 12:44:40 Mark Rivers wrote:
> Tim,
> You should not need to do this.  You can use standard Windows file
> paths, i.e. D:/EPICS/base-3.14.10.  You do, however, need a version of
> gnu make for Windows which is not the latest version from Cygwin.  The
> latest version on Cygwin does not work with the latest EPICS releases.
Alternatively use Make 3.81 from the MinGW toolkit, which has the same fix.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
AreaDetector, Compiling synApps modules for Windows Microsoft compiler Timothy Madden
RE: AreaDetector, Compiling synApps modules for Windows Microsoft compiler Mark Rivers
Prev: SSCAN MDA to database? IRMIS? Eric Berryman
Next: Stream Device RS-232 Protocol Mehta, Pratik
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: AreaDetector, Compiling synApps modules for Windows Microsoft compiler Mark Rivers
Next: SSCAN MDA to database? IRMIS? Eric Berryman
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
