1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stop all motors
To: Kate Feng <[email protected]>
Cc: [email protected]
Date: Tue, 13 Jan 2009 13:04:46 -0600
Hi Kate,
I believe the reason that the transform record was used was
because the dfanout record did not exist when this database
was written (but the transform record did).
Kurt
Kate Feng wrote:
Mark Rivers wrote:
Can you figure out why the transform record is causing the crash? It is widely used with no other problems that I know of.
You use vxWorks. We use RTEMS.
A generic record such as "dfanout" works very well for the purpose.
In fact, I do not think a custom record such as a "transform" record is needed.
Kate
Sent: Tue 1/13/2009 11:00 AM
To: [email protected]
Subject: stop all motors
If the "all_com_32.db" is loaded in the database, it triggered system
crash  while we were running one of our RTEMS applications.
I traced down that the bugs were caused by the "transform" record
(e.g. transformRecord.c) for the motor "allstop" function.  However,
a generic record "dfanout" can replace it to function correctly.
The attached all_com_32.db is what I used to solve the problem.
It seems to work so far.
Kate
#Kate Feng 12/30/2008:Use "dfanout" instead of "transform" for motor
"allstop"
grecord(bo,"$(P)allstop") {
    field(DOL,"1")
    field(OUT,"$(P)allstop1.VAL  PP MS")
grecord(bo,"$(P)gateOpen") {
    field(ZNAM,"Closed")
    field(ONAM,"Open")
grecord(calc,"$(P)alldoneBlinker") {
    field(SCAN,".5 second")
    field(CALC,"B?0:!A")
    field(INPA,"$(P)alldoneBlinker.VAL  NPP NMS")
    field(INPB,"$(P)alldone.VAL  NPP NMS")
grecord(dfanout,"$(P)allstop5") {
    field(DESC,"allstop distribution")
    field(OMSL,"closed_loop")
    field(DOL,"1")
    field(OUTA,"$(P)m25.STOP  CA MS")
    field(OUTB,"$(P)m26.STOP  CA MS")
    field(OUTC,"$(P)m27.STOP  CA MS")
    field(OUTD,"$(P)m28.STOP  CA MS")
    field(OUTE,"$(P)m29.STOP  CA MS")
    field(OUTF,"$(P)m30.STOP  CA MS")
    field(OUTG,"$(P)m31.STOP  CA MS")
    field(OUTH,"$(P)m32.STOP  CA MS")
grecord(dfanout,"$(P)allstop4") {
    field(DOL,"1")
    field(OUTA,"$(P)m17.STOP  CA MS")
    field(OUTB,"$(P)m18.STOP  CA MS")
    field(OUTC,"$(P)m19.STOP  CA MS")
    field(OUTD,"$(P)m20.STOP  CA MS")
    field(OUTE,"$(P)m21.STOP  CA MS")
    field(OUTF,"$(P)m22.STOP  CA MS")
    field(OUTG,"$(P)m23.STOP  CA MS")
    field(OUTH,"$(P)m24.STOP  CA MS")
grecord(dfanout,"$(P)allstop3") {
    field(DOL,"1")
    field(OUTA,"$(P)m9.STOP  CA MS")
    field(OUTB,"$(P)m10.STOP  CA MS")
    field(OUTC,"$(P)m11.STOP  CA MS")
    field(OUTD,"$(P)m12.STOP  CA MS")
    field(OUTE,"$(P)m13.STOP  CA MS")
    field(OUTF,"$(P)m14.STOP  CA MS")
    field(OUTG,"$(P)m15.STOP  CA MS")
    field(OUTH,"$(P)m16.STOP  CA MS")
grecord(dfanout,"$(P)allstop2") {
    field(DOL,"1")
    field(OUTA,"$(P)m1.STOP  CA MS")
    field(OUTB,"$(P)m2.STOP  CA MS")
    field(OUTC,"$(P)m3.STOP  CA MS")
    field(OUTD,"$(P)m4.STOP  CA MS")
    field(OUTE,"$(P)m5.STOP  CA MS")
    field(OUTF,"$(P)m6.STOP  CA MS")
    field(OUTG,"$(P)m7.STOP  CA MS")
    field(OUTH,"$(P)m8.STOP  CA MS")
grecord(dfanout,"$(P)allstop1") {
    field(DOL,"1")
    field(OUTA,"$(P)AbortScans.PROC  PP MS")
    field(OUTB,"$(P)allstop2.VAL  PP MS")
    field(OUTC,"$(P)allstop3.VAL  PP MS")
    field(OUTD,"$(P)allstop4.VAL  PP MS")
    field(OUTE,"$(P)allstop5.VAL  PP MS")
grecord(swait,"$(P)alldone") {
    field(DESC,"All motors done moving")
    field(SCAN,"I/O Intr")
    field(PINI,"YES")
    field(INAN,"$(P)alldone_1.VAL")
    field(INBN,"$(P)alldone_2.VAL")
    field(INCN,"$(P)alldone_3.VAL")
    field(INDN,"$(P)alldone_4.VAL")
    field(ININ,"$(P)gateOpen.VAL")
    field(CALC,"A&&B&&C&&D&&!I")
    field(DOLD,"1")
grecord(swait,"$(P)alldone_2") {
    field(DESC,"8 motors done moving")
    field(PINI,"YES")
    field(INAN,"$(P)m9.DMOV")
    field(INBN,"$(P)m10.DMOV")
    field(INCN,"$(P)m11.DMOV")
    field(INDN,"$(P)m12.DMOV")
    field(INEN,"$(P)m13.DMOV")
    field(INFN,"$(P)m14.DMOV")
    field(INGN,"$(P)m15.DMOV")
    field(INHN,"$(P)m16.DMOV")
    field(CALC,"(a&b&c&d&e&f&g&h)=1")
    field(OOPT,"Transition To Non-zero")
    field(DOLD,"1")
grecord(swait,"$(P)alldone_1") {
    field(PINI,"YES")
    field(INAN,"$(P)m1.DMOV")
    field(INBN,"$(P)m2.DMOV")
    field(INCN,"$(P)m3.DMOV")
    field(INDN,"$(P)m4.DMOV")
    field(INEN,"$(P)m5.DMOV")
    field(INFN,"$(P)m6.DMOV")
    field(INGN,"$(P)m7.DMOV")
    field(INHN,"$(P)m8.DMOV")
    field(DOLD,"1")
grecord(swait,"$(P)alldone_3") {
    field(PINI,"YES")
    field(INAN,"$(P)m17.DMOV")
    field(INBN,"$(P)m18.DMOV")
    field(INCN,"$(P)m19.DMOV")
    field(INDN,"$(P)m20.DMOV")
    field(INEN,"$(P)m21.DMOV")
    field(INFN,"$(P)m22.DMOV")
    field(INGN,"$(P)m23.DMOV")
    field(INHN,"$(P)m24.DMOV")
    field(DOLD,"1")
grecord(swait,"$(P)alldone_4") {
    field(PINI,"YES")
    field(INAN,"$(P)m25.DMOV")
    field(INBN,"$(P)m26.DMOV")
    field(INCN,"$(P)m27.DMOV")
    field(INDN,"$(P)m28.DMOV")
    field(INEN,"$(P)m29.DMOV")
    field(INFN,"$(P)m30.DMOV")
    field(INGN,"$(P)m31.DMOV")
    field(INHN,"$(P)m32.DMOV")
    field(DOLD,"1")
grecord(swait,"$(P)alldoneBlink") {
    field(INAN,"$(P)alldone")
    field(INBN,"$(P)alldoneBlinker")
    field(CALC,"a?0:b")
stop all motors Kate Feng
RE: stop all motors Mark Rivers
Re: stop all motors Kate Feng
Prev: Re: stop all motors Kate Feng
Next: Re: stop all motors Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: stop all motors Rarback, Harvey
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
