Dear Tech-talk,
Happy New Year :)
Here is a curious problem: the IOC we have been using without a
problem in the past all of a sudden will no longer read back correct
values, but it can still write them.
A little background information to set the stage. The supply is a CAEN
SY1527LC mainframe with four A1534P/N boards. The IOC was written by
Ru Igarashi from the Canadian Light Source (http://www.aps.anl.gov/epics/modules/manufacturer.php#CAEN
) and we modified it a little for our purposes at BNL during the
summer of 2006. No further modifications were made to the source code
since then.
Three months ago we were using the IOC without any problems. Last week
when I launched the IOC I noticed I could set parameters and turn on
channels – verified this via the built-in telnet interface of the
mainframe. However, I was no longer able to read back the channel
parameters properly. There is no error message, it just reads 0 all
the time. The PV which read the momentary voltage output always reads
0 now, similarly for the channel status PV and so on.
I did noticed with one PV it would retrieve the correct value
eventually. The initial current limit is 100uA and the read back PV
says as much. Then I set it to 50uA but read back 100uA – even after
the scan period has long expired. Set it to 75uA and now I read back
50uA.
The trouble shooting I have done thus far is (all of which was
unsuccessful):
re-compiled the IOC
turned off the firewall
verified the CAEN provided C wrapper library to which the IOC calls is
the same as the backup version
I used the demo program CAEN provided with the C wrapper library to
verify I can read out the channel parameters successfully with it – so
I believe the mainframe is fine.
Right now I am at a loss as to what has changed. The only thing I can
think of is we updated the system software via yum to the latest
Scientific Linux 4.x.
However, the vlinac and another IOC are fine.
Any thoughts or suggestions would be greatly appreciated,
Bertrand
P.S. I hope this is a really trivial problem due to some simple
misconfiguration I am not thinking of :)
Re: virtual linac with libstdc++.so.6 Andrew Johnson
Re: Problems getting edm functional on NetBSD David Dudley
<2009>
2025
2026
<2009>
2025
2026
