1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: RTEMS stack sizes
To: "Eric Norum" <[email protected]>, "Kate Feng" <[email protected]>
Cc: tech-talk Techtalk <[email protected]>
Date: Thu, 22 Jan 2009 10:54:26 -0500
THe fanout record was created in part to help limit the stack size used.
So each FLNK followed is a recursive call to record processing (pushes the context on the stack)
When you use a fanout record, then each path you follow with it's subsequent FLNK's use the stack this way - but before you follow the next FLNK fo the fanout record - you have cleared the stack of every context from the previous FLNK.
Bob
-----Original Message-----
Sent: Thu 1/22/2009 10:52 AM
To: Kate Feng
Subject: Re: RTEMS stack sizes
Would it make sense to provide an environment variable
(EPICS_THREAD_STACK_SIZE_MULTIPLIER?)  or several such variables
(EPICS_THREAD_STACK_SIZE_SMALL, _MEDIUM, _LARGE) to allow the default
values to be overridden?
On Jan 22, 2009, at 9:48 AM, Kate Feng wrote:
> Eric Norum wrote:
>> Right -- a huge FLNK chain will eat up lots of stack.  We found
>> this when we tried to FLNK 128 records....
>> I'm trying to find a size that's "good enough" for reasonable
>> cases.  The current RTEMS sizes are about the same as those of
>> vXWorks non-68k architecture machines and about twice that of
>> vxWorks 68k machines.
> It is a good idea to find a size that's "good enough" for default.
> It would be nice
> that those size could be custom defined at the
> configure/os/CONFIG.Common.RTEMS-bsp for various needs of
> applications.
> Kate
>> On Jan 22, 2009, at 9:23 AM, Jeff Hill wrote:
>>> Note that the CAS-client thread calls db_put_field, and as I
>>> recall the
>>> stack usage by db_put_field is dependent on the longest chain of
>>> records
>>> that might be manipulated in the database (due to the recursive
>>> implementation of the database).
>>>> From: [email protected] [mailto:[email protected]
>>>> On Behalf Of Eric Norum
>>>> Sent: Wednesday, January 21, 2009 8:01 PM
>>>> To: tech-talk Techtalk
>>>> Subject: RTEMS stack sizes
>>>> I'd like to solicit information from the EPICS community on the
>>>> stack
>>>> allocation for RTEMS IOCs.  Please check the stack usage of some of
>>>> your RTEMS IOCs and send me the results.   I would like to find
>>>> out if
>>>> it is possible and desirable to reduce the stack sizes to reduce
>>>> the
>>>> memory footprint for each client.
>>>> Here's the stack usage for one of the IOCs here (a ColdFire uCDIMM
>>>> 5282):
>>>>   PID   PRI STATE   %CPU %STK  NAME
>>>> 09010001 255 READY   35.8    0  IDLE
>>>> 0a01004c 180 READY   10.6   18  CAS-event
>>>> 0a01001c 134 Wmutex   9.7   23  scan0.2
>>>> 0a010004  10 Wevnt    6.0   19  ntwk
>>>> 0a010006  10 Wevnt    6.0   22  FECr
>>>> 0a01005b 180 READY    4.2   18  CAS-event
>>>> 0a010044 180 READY    3.5   19  CAS-event
>>>> 0a010071 180 READY    3.5   19  CAS-event
>>>> 0a010005  10 Wevnt    3.2   22  FECt
>>>> 0a010031 179 READY    3.1   19  save_restore
>>>> 0a010020 183 READY    3.0   22  CAS-UDP
>>>> 0a01001a 136 Wmutex   2.2   23  scan1
>>>> 0a010019 137 Wmutex   1.5   23  scan2
>>>> 0a01003f 180 READY    1.3   16  CAS-event
>>>> 0a010021 180 READY    1.2   18  CAS-event
>>>> 0a010007  10 Wevnt    0.9   22  RPCd
>>>> 0a01002e 179 READY    0.7   20  CAS-client
>>>> 0a01006a 179 READY    0.7   20  CAS-client
>>>> 0a01002c 179 Wevnt    0.4   20  CAS-client
>>>> 0a010048 179 Wevnt    0.3   20  CAS-client
>>>> 0a010018 138 Wmutex   0.3   23  scan5
>>>> 0a010042 179 Wevnt    0.3   20  CAS-client
>>>> 0a01004e 179 Wevnt    0.1   20  CAS-client
>>>> 0a01001d 133 Wmutex   0.1   24  scan0.1
>>>> 0a010053 180 READY    0.0   19  CAS-event
>>>> 0a01000d 149 Wmutex   0.0   20  L0
>>>> 0a01001b 135 Wmutex   0.0   24  scan0.5
>>>> 0a010011 129 Wmutex   0.0   23  timerQueue
>>>> 0a010073 180 READY    0.0   19  CAS-event
>>>> 0a01002b 179 Wevnt    0.0   20  CAS-client
>>>> 0a010012 140 Wmutex   0.0   23  cbLow
>>>> 0a010017 139 Wmutex   0.0   20  scan10
>>>> 0a01005c 108 READY    0.0   16  SPY
>>>> 0a01000e 109 Wevnt    0.0   17  timeBroadcastMonitor
>>>> 0a010027 148 DELAY    0.0   23  seqAux
>>>> 0a010067 180 Wmutex   0.0   24  CAS-event
>>>> 0a010065 180 Wmutex   0.0   24  CAS-event
>>>> 0a010066 179 Wevnt    0.0   23  CAS-client
>>>> 0a01005f 180 Wmutex   0.0   19  CAS-event
>>>> 0a010062 179 Wevnt    0.0   20  CAS-client
>>>> 0a010078 179 Wevnt    0.0   23  CAS-client
>>>> 0a010076 179 Wevnt    0.0   23  CAS-client
>>>> 0a010074 179 Wevnt    0.0   20  CAS-client
>>>> 0a01006d 180 Wmutex   0.0   19  CAS-event
>>>> 0a010057 180 Wmutex   0.0   24  CAS-event
>>>> 0a010043 179 Wevnt    0.0   23  CAS-client
>>>> 0a01004b 179 Wevnt    0.0   20  CAS-client
>>>> 0a010054 179 Wevnt    0.0   20  CAS-client
>>>> 0a010052 179 Wevnt    0.0   23  CAS-client
>>>> 0a010051 180 Wmutex   0.0   19  CAS-event
>>>> As you can see, no thread is using more then one quarter of its
>>>> allocated stack space.
>>>> The current stack allocations are:
>>>>    epicsThreadStackSmall:  stackSize =  8000
>>>>    epicsThreadStackMedium: stackSize = 12000
>>>>    epicsThreadStackBig:   stackSize = 16000
>>>> Perhaps these could be reduced by 30 to 50 percent???
>>>> Each client results in the allocation of a 'Big' stack for the CAS-
>>>> client thread and a 'Medium' stack for the CAS-event thread.
>>>> Eric Norum <[email protected]>
>>>> Advanced Photon Source
>>>> Argonne National Laboratory
>>>> (630) 252-4793
>> --Eric Norum <[email protected]>
>> (630) 252-4793
(630) 252-4793
RTEMS stack sizes Eric Norum
Re: RTEMS stack sizes Eric Norum
Re: RTEMS stack sizes Kate Feng
Prev: Re: RTEMS stack sizes Eric Norum
Next: Re: RTEMS stack sizes Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
