1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Very slow reconnection to medm after IOC reboot
To: "Jeff Hill" <[email protected]>, "Andrew Johnson" <[email protected]>, "epics" <[email protected]>
Date: Thu, 22 Jan 2009 15:32:47 -0600
I noticed that when I start win32-x86 IOCs built with 3.14.10 I get the
following message just after iocInit:
The CA server's beacon address list was empty after initialization?
I do not get this message when running the identical IOC built with
3.14.8.2.
Is this significant?  Why am I getting this message?
-----Original Message-----
Sent: Thursday, January 22, 2009 12:43 PM
To: 'Jeff Hill'; 'Andrew Johnson'; epics
Subject: Very slow reconnection to medm after IOC reboot
Folks,
I have noticed a problem which seems new, though I can't say exactly
when it started.
The time for EPICS CA clients to reconnect when an IOC reboots is quite
long.
Here are some specifics.  I am running a soft IOC on Linux or Windows
and running medm on Linux or Windows.  There are 4 medm screens opened
to the IOC with about 200 PVs total.  There are 2 computers under test:
a recent Redhat Linux machine and a Windows XP machine.  They are on the
same subnet.  caRepeater is running on both machines.
Linux IOC (3.14.10), Linux medm client (built with 3.14.8.2) on the same
machine.
Stop IOC, wait 10 seconds, restart IOC.
Time for medm to reconnect all channels: less than 10 seconds.
Stop IOC, wait 8 minutes, restart IOC.
Time for medm to reconnect first channel: 40 seconds
Time for medm to reconnect all channels: 60 seconds
Windows IOC (3.14.10), same Linux medm client (built with 3.14.8.2)
Stop IOC, wait 15 minutes, restart IOC.
After 3 minutes no channels had reconnected.  Open a new medm screen to
the same IOC.  It immediately connects all PVs on the new screen, but
the PVs on the previous screens are still not connected.
Time for medm to reconnect all channels: 4 minutes (finally after 4
minutes all PVs on the previous screens reconnected.
Windows IOC (3.14.10), Windows medm client (built with 3.14.9) on same
PC.
Time for medm to reconnect first channel: 60 seconds
Time for medm to reconnect all channels: 4 minutes and 25 seconds.
This definitely seems like a new problem to me, it never used to take 4
minutes to reconnect.  Unfortunately I have recently upgraded both medm
(from a much older version, to the newer one built with 3.14.8.2) and
the IOCs (from 3.14.8.2 to 3.14.10).
On the Windows PC I have the following EPICS environment variables
defined:
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_HOST_ARCH=win32-x86
EPICS_CA_ADDR_LIST=localhost 164.54.160.255
EPICS_DISPLAY_PATH=C:\EPICS\adls\
EPICS_CA_MAX_ARRAY_BYTES=10000000
On the Linux machine I have the following EPICS environment variables
defined:
EPICS_HOST_ARCH=linux-x86
EPICS_DISPLAY_PATH=/home/epics/adl/all
These delays make IOC development very painful, particularly on Windows.
Each time I restart the IOC if I wait more than 30 seconds or so it then
takes 4 minutes for the medm screens to refresh.  It becomes quicker to
close them all and re-open them, though this is very tedious.
Have others seen similar problems?  Any idea when they started?  Do they
go away if clients are built with 3.14.10 which I have not tried (but I
have used 3.14.9)
Re: Very slow reconnection to medm after IOC reboot Andrew Johnson
Very slow reconnection to medm after IOC reboot Mark Rivers
Prev: Re: vdct problem with quoted strings Andrew Johnson
Next: Re: Very slow reconnection to medm after IOC reboot Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Very slow reconnection to medm after IOC reboot J. Lewis Muir
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
