1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MEDM EPICS Win32 Extensions
To: Paul Sichta <[email protected]>
Date: Thu, 22 Jan 2009 15:20:45 -0800
I have run into that before but that is not the problem. I have the mouse hovering over the text field in question and nothing is entered.
I was reading up on a previous thread on tech talk where my exact problem was reported but the fix does not help my situation.
http://www.aps.anl.gov/epics/tech-talk/2007/msg01116.php
I also did a search to see if the issue was related specifically to cygwin and it appears to be so. I believe it has to do with the environment variable XKEYSYMDB. If it is set, I cannot use xterm or medm.
Anyone have any other thoughts? This is a fresh install of cygwin and I copied the XKeySymDB file from this cygwin install to the epics dir and pointed the environment variable at that.
Thanks.
-Richard
-----Original Message-----
Sent: Thursday, January 22, 2009 11:13 AM
To: Richard Pastrick
Cc: [email protected]
Subject: Re: MEDM EPICS Win32 Extensions
Not sure if this is your issue but:
On medm when you poke inside a text entry field, the cursor must remain
inside the text entry field until you type in your text and hit the
enter key.
-ps
Richard Pastrick wrote:
> I am having some very interesting problems with the MEDM EPICS Win32 extensions.
> I can get the MEDM window to start up and connect to a motor record using cygwin's xserver but I cannot interact with any of the text entry elements in the window. I can press the buttons and see the effect there.
> I have another computer that I set up in the same way and it works just fine using cygwin's xserver. I have all of the environment variables set that are defined in the Readme.txt in the EPICS WIN32 Extensions folder after it is installed.
> Any thoughts?
> Thanks.
> Richard Pastrick
> Associate Software Engineer
> Xradia Inc
> 5052 Commercial Cir
> Concord CA 94520
> 925-288-1228 Ext 1151
> 925-348-0384 (cell)
> ________________________________
> The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
Re: MEDM EPICS Win32 Extensions J. Lewis Muir
MEDM EPICS Win32 Extensions Richard Pastrick
Re: MEDM EPICS Win32 Extensions Paul Sichta
Prev: RTEMS soft reboot Matt Rippa
Next: Re: MEDM EPICS Win32 Extensions J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MEDM EPICS Win32 Extensions Paul Sichta
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
