1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS soft reboot
To: Matt Rippa <[email protected]>
Cc: EPICS-tech-talk <[email protected]>
Date: Fri, 23 Jan 2009 09:59:57 -0500
Till Straumann wrote:
Matt Rippa wrote:
Running 'exit' on an RTEMS ioc I get a stack trace. Is exit the intended mechanism for a soft reboot?
Well - 'exit' should bring you back to the point where you
started RTEMS. However, this is not really possible on all
boards because the environment that booted RTEMS may
have been destroyed (in your case, RTEMS overwrites
critical memory that was used by PPCBug) and in this case
a hard reset may be required (IIRC, 'exit' should in these
cases do that for you so you may have encountered a bug).
Different BSPs used to have their own API to reset the board
(PPC/shared boards used to call this rtemsReboot(), IIRC)
but, again IIRC, this should have been made more consistent
(don't recall if this happened before or after forking 4.9) and
renamed 'bsp_reset()' across multiple architectures/boards.
Now that I write all this I believe I remember that the old
motorola BSP (mvme2300..2700) indeed has a bug; it tries
to reset via the KBD controller and (again IIRC) that doesn't
work. If it did, rtemsReboot()/bsp_reset() or 'exit()' should both
do the job...
On the mvme5500 and mvme6100 board,  there is a board reset
command which I found from the "programmer's manual".
Perhaps, you can find one for the mvme2700 , too.
Kate
You should be able to reset the board via a VME sysreset
(vmeUniverseResetBus())
-- T.
I've shown gdb output below. This is running on an MVME-2700.
-Matt
EPICS 3.14.10 /RTEMS 4.9.1
10.1.5.253> exit
Printing a stack trace for your convenience :-)
0x0011A8E0--> 0x0010F55C--> 0x0010A888--> 0x0010A76C--> 0x0000322C
gdb shows:
(gdb) x 0x0000322C
0x322c <enter_C_code+68>:       0x4800004d
(gdb)
0x3230 <MMUon>: 0x7c0000a6
(gdb)
0x3234 <MMUon+4>:       0x6000a972
(gdb)
0x3238 <MMUon+8>:       0x68008940
(gdb)
0x323c <MMUon+12>:      0x7d6802a6
(gdb)
0x3240 <MMUon+16>:      0x7d7a03a6
(gdb)
0x3244 <MMUon+20>:      0x7c1b03a6
(gdb)
0x3248 <MMUon+24>:      0x7c0004ac
(gdb)
0x324c <MMUon+28>:      0x4c00012c
(gdb)
0x3250 <MMUon+32>:      0x4c000064
(gdb)
0x3254 <MMUoff>:        0x7c0000a6
(gdb)
0x3258 <MMUoff+4>:      0x60000070
(gdb)
0x325c <MMUoff+8>:      0x7d6802a6
(gdb)
0x3260 <MMUoff+12>:     0x68000030
(gdb)
0x3264 <MMUoff+16>:     0x7d7a03a6
(gdb)
0x3268 <MMUoff+20>:     0x7c1b03a6
(gdb)
0x326c <MMUoff+24>:     0x7c0004ac
(gdb)
0x3270 <MMUoff+28>:     0x4c00012c
(gdb)
0x3274 <MMUoff+32>:     0x4c000064
(gdb)
0x3278 <_return_to_ppcbug>:     0x7fc802a6
(gdb)
RTEMS soft reboot Matt Rippa
Re: RTEMS soft reboot Till Straumann
Prev: Re: stop all motors Kate Feng
Next: RE: Very slow reconnection to medm after IOC reboot Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RTEMS soft reboot Till Straumann
Next: Re: RTEMS soft reboot Matt Rippa
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
