I just ran into a surprising behaviour of the subArray-record.
What I wanted to do:
* Source is a waveform of 2048 shorts.
* my subArray should slice out the last 4 values of the source-array
(actually split the source-array into hundreds of sub-arrays)
record(subArray,"slice") {
field(INP,"hugeWaveform CPP NMS")
field(FTVL,"SHORT")
field(MALM,"4")
field(NELM,"4")
field(INDX,"2044")
* surprisingly, my subArray-record was crippled after processing and had
INDX = 3, NORD = 1
Looking at the source-code I found the following in
subArrayRecord.c:readValue(psa)
if (psa->indx >= psa->malm)
psa->indx = psa->malm - 1;
Since the INDX actually has nothing to do with the subArray-record
itself, but is just an index into the referenced waveform (of unknown
size), to me it makes no sense at all to limit INDX to MALM-1.
For me the only solution is to set MALM of my subArray to INDX+NELM
which leads to hundreds of oversized and allocated arrays in my
subArray-records.
E.g. to slice out the last element of a waveform, I have to
(statically!) allocate space for the whole source-waveform and then copy
exactly one element.
I simply ask to drop these 4 lines of code from subArrayRecord.c - it
shouldn't even break existing installations, and for my case I could
reduce memory-consumption a lot.
Thomas
Thomas Birke
Operation Controls
Elektronenspeicherring BESSY II
Albert-Einstein-Str. 15, 12489 Berlin
Fon +49 30 6392 4934
Fax +49 30 6392 4859
Glienicker Straße 100, 14109 Berlin
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertretende Vorsitzende: Dr. Jutta Koch-Unterseher
Geschäftsführer: Prof. Dr. Anke Rita Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Sitz der Gesellschaft: Berlin Handelsregister: AG Charlottenburg, 89 HRB 5583
Information:
Durch die Fusion mit dem ehemaligen Hahn-Meitner-Institut (HMI) ist
BESSY nun Teil des neuen Helmholtz-Zentrum Berlin für Materialien
und Energie (HZB).
By the merger with the former Hahn-Meitner-Institut (HMI), BESSY
became part of the new Helmholtz-Zentrum Berlin für Materialien und
Energie (HZB).
Disclaimer automatically attached by the E-Mail Security Appliance
mail0.bessy.de 02/04/09 at Helmholtz-Zentrum Berlin GmbH.
- Re: Problem with subArray - unnecessary memory allocation Thomas Birke
RE: Changes to PCAS in 3.14 Jeff Hill
<2009>
2025
2026
<2009>
2025
2026
