1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MaxP PCI motor interface
To: "Dalesio, Leo" <[email protected]>
Cc: [email protected]
Date: Wed, 04 Feb 2009 19:05:29 +0100
Dalesio, Leo schrieb:
> Does anyone have a driver for this?
> Thanks,
> Bob
Hi Bob,
I have written a MAXp asynDriver for the MotorRecord running on Linux.
I'll send it to you.
It needs some cleanup, but it works.
I had to modify the linux kernel modul, which I took from the
Pro-Dex website, because that did not work.
(Btw. the kernel driver is part of Greg Kroah-Hartman's staging kernel, so it
may be part of the regular linux kernel in the future)
Unfortunately the 120pin Molex connector (cable connector and pcb connector) of the
MAXp is not available any more!
Pro-Dex say, they will come up with a new connector on their card, but by now they
only have a few pcb-dongles with two 68pin connectors available.
Don't purchase a MAXp card without having solved the cable problem.
Jens
MaxP PCI motor interface Dalesio, Leo
Prev: Incompatibility between alh and excas in 3.14.10 Elliott Wolin
Next: Codeathon: Calling twice... Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MaxP PCI motor interface Dalesio, Leo
Next: SNCSEQ Path Problems Pawel Kowalski - BiRa Systems Inc.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
