1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Add vxstats to an application
To: "Mi Qingru" <[email protected]>, "epics tech-talk" <[email protected]>
Date: Sun, 15 Feb 2009 21:22:31 -0600
Hi Qingru,
As I suspected the error is happening when it is building the application for Linux, not when it is being built for vxWorks.
This is because your Makefile contains the lines:
-------testApp/src/Makefile-------------
test_DBD += vxStats.dbd
test_LIBS_vxWorks += vxStats
So you have told it to build the application with the vxStats.dbd file for both vxLinux and vxWorks, but you have only told it to use the vxStats library on vxWorks.
You need to change your Makefile to either not build the application at all on Linux, or to only include the vxStats.dbd file on vxWorks, not on all platforms.
Sent: Sun 2/15/2009 7:33 PM
To: Mark Rivers; epics tech-talk
Subject: Re: Add vxstats to an application
I am so sorry for the late reply and the lost topic.
The following is the out of  make after make clean.
make -C configure install
make[1]: Entering directory `/home/blctrl/epics/vxstatsTest/configure'
perl /BLC/epics/base/configure/tools/convertRelease.pl -h linux-x86 checkRelease
perl /BLC/epics/base/configure/tools/makeMakefile.pl O.linux-x86 ../..
perl /BLC/epics/base/configure/tools/makeMakefile.pl O.vxWorks-ppc604_long ../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
make[2]: Entering directory `/home/blctrl/epics/vxstatsTest/configure/O.linux-x86'
perl /BLC/epics/base/configure/tools/convertRelease.pl -h linux-x86 CONFIG_APP_INCLUDE
perl /BLC/epics/base/configure/tools/convertRelease.pl -h linux-x86 RULES_INCLUDE
make[2]: Leaving directory `/home/blctrl/epics/vxstatsTest/configure/O.linux-x86'
make -C O.vxWorks-ppc604_long -f ../Makefile TOP=../.. T_A=vxWorks-ppc604_long install
make[2]: Entering directory `/home/blctrl/epics/vxstatsTest/configure/O.vxWorks-ppc604_long'
make[2]: Leaving directory `/home/blctrl/epics/vxstatsTest/configure/O.vxWorks-ppc604_long'
make[1]: Leaving directory `/home/blctrl/epics/vxstatsTest/configure'
make -C vxstatsTestApp install
make[1]: Entering directory `/home/blctrl/epics/vxstatsTest/vxstatsTestApp'
make -C src install
make[2]: Entering directory `/home/blctrl/epics/vxstatsTest/vxstatsTestApp/src'
perl /BLC/epics/base/configure/tools/makeMakefile.pl O.linux-x86 ../../..
perl /BLC/epics/base/configure/tools/makeMakefile.pl O.vxWorks-ppc604_long ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `/home/blctrl/epics/vxstatsTest/vxstatsTestApp/src/O.linux-x86'
make[3]: Leaving directory `/home/blctrl/epics/vxstatsTest/vxstatsTestApp/src/O.linux-x86'
perl /BLC/epics/base/configure/tools/makeIncludeDbd.pl base.dbd xxxSupport.dbd dbSubExample.dbd vxstatsTestHello.dbd vxStats.dbd ../O.Common/vxstatsTestInclude.dbd
Expanding dbd
/BLC/epics/base/bin/linux-x86/dbExpand  -I . -I .. -I ../../../dbd -I /BLC/epics/base/dbd -I /BLC/epics/base/../synApps_5_3/support/vxStats/1-7-2e/dbd -o ../O.Common/vxstatsTest.dbd ../O.Common/vxstatsTestInclude.dbd
Installing dbd file ../../../dbd/vxstatsTest.dbd
/BLC/epics/base/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd -I /BLC/epics/base/dbd -I /BLC/epics/base/../synApps_5_3/support/vxStats/1-7-2e/dbd  ../xxxRecord.dbd ../O.Common/xxxRecord.h
Installing generated generic include file ../../../include/xxxRecord.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include -I/BLC/epics/base/include/os/Linux -I/BLC/epics/base/include        ../xxxRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include -I/BLC/epics/base/include/os/Linux -I/BLC/epics/base/include        ../devXxxSoft.c
/usr/bin/ar -rc   libxxxSupport.a      xxxRecord.o devXxxSoft.o
/usr/bin/ranlib libxxxSupport.a
Installing library ../../../lib/linux-x86/libxxxSupport.a
/usr/bin/ranlib ../../../lib/linux-x86/libxxxSupport.a
/usr/bin/g++ -o libxxxSupport.so -shared -fPIC -L/BLC/epics/base/lib/linux-x86/         -Wl,-rpath,/home/blctrl/epics/vxstatsTest/lib/linux-x86 -Wl,-rpath,/BLC/epics/base/lib/linux-x86        xxxRecord.o devXxxSoft.o    -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libxxxSupport.so
perl /BLC/epics/base/bin/linux-x86/registerRecordDeviceDriver.pl ../O.Common/vxstatsTest.dbd vxstatsTest_registerRecordDeviceDriver > temp.cpp
mv temp.cpp vxstatsTest_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include -I/BLC/epics/base/include/os/Linux -I/BLC/epics/base/include        vxstatsTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include -I/BLC/epics/base/include/os/Linux -I/BLC/epics/base/include        ../dbSubExample.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include -I/BLC/epics/base/include/os/Linux -I/BLC/epics/base/include        ../vxstatsTestHello.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include -I/BLC/epics/base/include/os/Linux -I/BLC/epics/base/include        ../vxstatsTestMain.cpp
/usr/bin/g++ -o vxstatsTest  -L../../../lib/linux-x86/ -L/BLC/epics/base/lib/linux-x86/         -Wl,-rpath,/home/blctrl/epics/vxstatsTest/lib/linux-x86 -Wl,-rpath,/BLC/epics/base/lib/linux-x86        vxstatsTest_registerRecordDeviceDriver.o dbSubExample.o vxstatsTestHello.o vxstatsTestMain.o    -lxxxSupport -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
make[2]: Leaving directory `/home/blctrl/epics/vxstatsTest/vxstatsTestApp/src'
make[1]: Leaving directory `/home/blctrl/epics/vxstatsTest/vxstatsTestApp'
vxstatsTest_registerRecordDeviceDriver.o(.text+0x40): In function `vxstatsTest_registerRecordDeviceDriver':
/home/blctrl/epics/vxstatsTest/vxstatsTestApp/src/O.linux-x86/vxstatsTest_registerRecordDeviceDriver.cpp:258: undefined reference to `pvar_func_registerReboot'
vxstatsTest_registerRecordDeviceDriver.o(.text+0xa7): In function `registerRecordDeviceDriverCallFunc':
vxstatsTest_registerRecordDeviceDriver.o(.text+0x32d): In function `global constructors keyed to vxstatsTest_registerRecordDeviceDriver':
/home/blctrl/epics/vxstatsTest/vxstatsTestApp/src/O.linux-x86/vxstatsTest_registerRecordDeviceDriver.cpp:234: undefined reference to `pvar_dset_devAiStats'
vxstatsTest_registerRecordDeviceDriver.o(.text+0x33d):/home/blctrl/epics/vxstatsTest/vxstatsTestApp/src/O.linux-x86/vxstatsTest_registerRecordDeviceDriver.cpp:234: undefined reference to `pvar_dset_devAiClusts'
vxstatsTest_registerRecordDeviceDriver.o(.text+0x365):/home/blctrl/epics/vxstatsTest/vxstatsTestApp/src/O.linux-x86/vxstatsTest_registerRecordDeviceDriver.cpp:234: undefined reference to `pvar_dset_devAoStats'
vxstatsTest_registerRecordDeviceDriver.o(.text+0x475):/home/blctrl/epics/vxstatsTest/vxstatsTestApp/src/O.linux-x86/vxstatsTest_registerRecordDeviceDriver.cpp:234: undefined reference to `pvar_dset_devStringinStats'
collect2: ld returned 1 exit status
make[3]: *** [vxstatsTest] Error 1
make[2]: *** [install.linux-x86] Error 2
make[1]: *** [src.install] Error 2
make: *** [vxstatsTestApp.install] Error 2
Mi Qingru
----- Original Message -----
To: "Mi Qingru" <[email protected]>; "epics tech-talk" <[email protected]>
Sent: Thursday, February 12, 2009 9:02 PM
Subject: RE:
It looks to me like maybe that error is happening when EPICS is building the IOC for you host architecture, not for vxWorks.  You have told it to use the vxStats library for vxWorks, but not for your host (Linux?).
Please send much more of the output just before the errors so we can see just what is being done at the time you get the errors.
Sent: Wed 2/11/2009 11:28 PM
Subject: Re:
Yes, I did.
Sent: Wednesday, February 11, 2009 9:28 PM
Subject: RE:
After making those changes to RELEASE and Makefile did you do "make clean" before doing "make"?
Sent: Wed 2/11/2009 2:27 AM
To: epics tech-talk
Subject:
Hello,
I make an application , and add vxStats of synApps to it.
-------configure/RELEASE-------------
VX_STATS=$(EPICS_SYNAPPS)/support/vxStats/1-7-2e
But when make, there are a few errors:
test_registerRecordDeviceDriver.cpp: undefined reference to 'pvar_func_registerReboot'
test_registerRecordDeviceDriver.cpp: undefined reference to 'pvar_dset_devAiStats'
test_registerRecordDeviceDriver.cpp: undefined reference to 'pvar_dset_devAiClusts'
test_registerRecordDeviceDriver.cpp: undefined reference to 'pvar_dset_devAoStats'
test_registerRecordDeviceDriver.cpp: undefined reference to 'pvar_dset_devStringinStats'
How to resolve the problem?
Thanks a lot!
Mi QingRu
__________ Information from ESET Smart Security, version of virus signature database 3846 (20090211) __________
The message was checked by ESET Smart Security.
http://www.eset.com <http://www.eset.com/>  <http://www.eset.com/>
__________ Information from ESET Smart Security, version of virus signature database 3853 (20090214) __________
Re: Add vxstats to an application Mi Qingru
[no subject] Mi Qingru
RE: Mark Rivers
Re: Mi Qingru
RE: Mark Rivers
Prev: Re: Add vxstats to an application Mi Qingru
Next: Re: Add vxstats to an application Mi Qingru
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
