1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: cap5 Perl library
To: <[email protected]>
Date: Wed, 18 Feb 2009 13:52:06 +0100
Hello all,
I am trying to make some tests with the perl ca library provided by Andrew Johnson.
I have the following error:
perl mytest.pl
Can't locate loadable object for module Cap5 in @INC (@INC contains: /home/spiral2mgr/APPLICATIONS/PERL/cap5-0.1/lib/perl /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.7/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.6/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl/5.8.7 /usr/lib/perl5/site_perl/5.8.6 /usr/lib/perl5/site_perl/5.8.5 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.7/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.6/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl/5.8.7 /usr/lib/perl5/vendor_perl/5.8.6 /usr/lib/perl5/vendor_perl/5.8.5 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .) at mytest.pl line 3
Compilation failed in require at mytest.pl line 3.
BEGIN failed--compilation aborted at mytest.pl line 3.
[spiral2mgr@dappck110 cap5-0.1]$ pwd
[spiral2mgr@dappck110 cap5-0.1]$ more mytest.pl
    use lib '/home/spiral2mgr/APPLICATIONS/PERL/cap5-0.1/lib/perl';
use CA;
    my $chan = CA->new('LBE1-D11:IConsR');
    my $chan1 = CA->new('LBE1-D11:ICons');
    CA->pend_io(1);
Being not a real perl expert, I can’t understand why this module is not found.
By the way, I installed this package some time ago, and I am now unable to find it on the Epics server (except the documentation) ???
Maybe I have to reinstall it as I changed the name of the APPLICATIONS directory (I saw a hard-wired directory path in CA.pm and maybe I missed some).
Thanks
J.F. Gournay
CEA Saclay
IRFU/SIS
Re: cap5 Perl library Andrew Johnson
Prev: New EPICS architecture: ARM EABI Michael Abbott
Next: Re: cap5 Perl library Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
