each string's offset by MAX_STRING_SIZE, try the following
for (i=o;i<precord->novn,i++)
snprintf ((char*)precord->valn+i*MAX_STRING_SIZE,MAX_STRING_SIZE,
"Defect String %d",i );
haquin wrote:
Hi all,
I have configured a gensub record to output a string array but this
doesn't work.
I set the following genSub fields:
FTVN:STRING
NOVN:12
in my process function I do the following:
sprintf ((char*)precord->valn, "Defect String 1");
sprintf ( (char*)(((char**)(precord->valn))+1), "Defect String 2");
When I execute the IOC, the output is the following:
epics> dbgf IOCASTE-TST:ProcessDynamicModbusTable.VALN
DBR_STRING: DefeDefect String 2
the second string has overwritten the first one.
It seems that there only one string
thanks in advance for your help.
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- Re: can't output strings array with gensub Eric Norum
- can't output strings array with gensub haquin
Re: soft device for ai record works as sscanf. Benjamin Franksen
Re: soft device for ai record works as sscanf. Noboru Yamamoto
<2009>
2025
2026
<2009>
2025
2026
