1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget with an array of space-containing strings
To: EPICS Tech Talk <[email protected]>
Date: Fri, 27 Feb 2009 01:23:17 +0100
In general I would second Andrew's statement. Looping over CA command line tool calls would be bad behaviour in terms of CA.
I have to admit, though, that arrays of strings with embedded spaces break one of the command line tools' underlying ideas: caput understands the caget return value of the same PV.
So, an command line option to change the separator could be a feasible solution, or quoting those strings, or both. Any preferences?
Ralph
Re: caget with an array of space-containing strings J. Lewis Muir
Re: caget with an array of space-containing strings Andrew Johnson
caget with an array of space-containing strings Carl Schumann
Prev: Re: caget with an array of space-containing strings Andrew Johnson
Next: Re: caget with an array of space-containing strings Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget with an array of space-containing strings J. Lewis Muir
Next: Re: caget with an array of space-containing strings J. Lewis Muir
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
