Hi Dirk,
The relevant mantis issue is in fact entry 329.
> I can try:
> - pChan->getPV()->pPVI->deleteSignal ();
> Jeff, do you think that will do?
That should take care of the problem.
Jeff
> -----Original Message-----
> From: Dirk Zimoch [mailto:[email protected]]
> Sent: Monday, March 02, 2009 8:48 AM
> To: Martin L. Smith; Jeff Hill
> Cc: tech-talk
> Subject: Re: Useless error messages in EPICS
> Hi Martin,
> Thanks for the hint.
> I still use R3.14.8.2. The code looks a bit different:
> if ( status != S_cas_success ) {
> this->chanTable.remove ( *pChan->pChanI );
> this->chanList.remove ( *pChan->pChanI );
> pChan->pChanI->uninstallFromPV ( this->eventSys );
> delete pChan->pChanI;
> return status;
> I can try:
> Dirk
> Martin L. Smith wrote:
> > Hi Dirk,
> > I ran into this same problem back in January and it turns out that this
> > is Mantis entry 329. Jeff Hill made a fix for this; from a previous
> > email that I still have:
> > diff -u -b -w -b -r1.92.2.16 casStrmClient.cc
> > --- casStrmClient.cc 21 Oct 2008 20:50:26 -0000 1.92.2.16
> > +++ casStrmClient.cc 8 Jan 2009 22:13:09 -0000
> > @@ -1413,9 +1413,7 @@
> > - casPVI * pPVI = pChan->getPV()->pPVI;
> > - pPVI->deleteSignal ();
> > return status;
> > After Janet Anderson rebuilt the GW using this fix, which should be
> > committed to the repository, I have not had this problem since.
> > Marty
> > Dirk Zimoch wrote:
> >> Hi all,
> >> This night, I had a problem with a CA gateway. The log file contained
> >> the following error messages:
> >>> epicsMutex pthread_mutex_lock failed: error Invalid argument
> >>> Mar 02 00:04:46 !!! Errlog message received (message is above)
> >>> fatal error: epicsMutexOsdLock
> >> I found these messages not very helpful because they do not tell me
> >> where the error occurred and why the argument is invalid. This makes
> >> it impossible to debug the problem.
> >> Unfortunately, this is often the case with EPICS errors. I observe
> >> three problems with locations of errors:
> >> 1. The error message does not give any hint of the location at all.
> >> 2. The reported location is inside a (EPICS) system function or a
> >> macro, but the caller who actually caused the error is not reported.
> >> 3. The reported location is inside the source code of a file parser
> >> but the error location in the faulty file is not reported.
> >> In this case, we have situation 2. The problem occurred in
> >> epicsMutexOsdLock(), but this function is called at so many places in
> >> EPICS that it's impossible to track down the origin of the fault.
> >> When looking into epicsMutexOsdLock(), I found that the calling thread
> >> is suspended via a call to cantProceed() when an error happens. In my
> >> opinion, this is as well not very helpful because the calling function
> >> does not get any indication of the failure and thus cannot print a
> >> proper error message.
> >> In my opinion, cantProceed() does more harm than good as long as it is
> >> not able to provide useful debug information (at least a stack trace)
> >> -- which is probably hard to do in a portable way. I think, a call to
> >> abort() would be more helpful as it produces a process dump (at least
> >> on Unix systems) which can be analyzed.
> >> Generally, error handling should not be part of the low-level
> >> functions. These functions do not have any application knowledge and
> >> thus cannot decide if suspending the thread, terminating the program,
> >> printing an error message or continuing normally is the "correct"
> >> behavior. Instead, low-level functions should only report errors (by
> >> or exceptions or return values -- I am not religious in this matter)
> >> and leave the choice of the correct response to the caller.
> >> In this case, the gateway (maybe the CAS library) stopped accepting
> >> new clients which made it effectively useless. On the other hand, it
> >> did not terminate. Thus any mechanism to restart the gateway on
> >> failure does not work, too. I do not consider this a "useful" behavior.
> >> It may be a goal of the next codathlon to improve the error messages
> >> provided by EPICS.
> >> Dirk
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
- Useless error messages in EPICS Dirk Zimoch
- Re: Useless error messages in EPICS Martin L. Smith
- Re: Useless error messages in EPICS Dirk Zimoch
Re: Useless error messages in EPICS Andrew Johnson
Where to find CA.DLL version 3.14.8? Richard Swent
<2009>
2025
2026
<2009>
2025
2026
