Greetings, EPICS users.
I am trying to use streamDevice with regular expression support to parse
input from an instrument containing an embedded web server. So far, I've
successfully built and run the streamApp sample IOC that gets built with
the streamDevice distribution. I am able to parse a single HTML element
(TITLE, with minor mods to the example protocol file) from a static web
page served by an Apache web server. So, I think I've built everything
properly (streamDevice 2.4, asyn 4-9, EPICS 3.14.10, Linux=Scientific
Linux 4.x).
My difficulty is that the instrument produces a page containing three
strings that I wish to extract into three EPICS records. I'm testing
with string-in records for now, but eventually I would prefer to scan to
analog-in records. I am able to extract the first element from the HTML,
although I do get error messages from streamDevice:
"Input "HTTP/1.0 200 OK<0d><0a>Con..." does not match format
%.1/^MeasurePM*([0-9.]+)/"
However, I am unsure about how to get multiple fields scanned from the
HTML using a single HTTP GET. I would really like to avoid doing one
whole HTTP fetch per record, since the instrument is fairly primitive,
and can probably become overwhelmed by excessive traffic, and it may be
the case that readings on a single fetch are synchronized in time.
From my interpretation of the documentation, the scanner should stop,
leaving unread text in the pipeline once it has made a successful match.
However, I don't understand how to continue scanning the remainder of
the HTML page to extract the remaining data.
I attach below, the streamDevice protocol file I'm presently using (the
latest flavor that gets me closest to working), the relevant database,
and the entire HTML that the instrument returns. Much of this is based
on the examples from streamDevice.
#=========================<protocol file>=============================
# regular expression example
# extract the title of from a web page
outterminator = NL;
interminator = "</HTML>"; # terminators can have arbitrary length
# Web servers close the connection after sending a page.
# Thus, we can't use autoconnect (see drvAsynIPPortConfigure)
# Handle connection manually in protocol.
readTitle {
extraInput=ignore;
connect 1000; # connect to server, 1 second timeout
out "GET http://isacwserv.triumf.ca"; # HTTP request
in "%.1/<TITLE>(.+)<\/TITLE>/"; # get string in <TITLE></TITLE>
disconnect;
readPPM {
extraInput=ignore;
out "GET http://142.90.132.71/lcd.cgi"; # HTTP request
in "%.1/^Measure\(PPM\):\s*([0-9.]+)/"; # get string in Measure
field
readFLOW {
extraInput=ignore;
in "%.1/^Sample flow\(CC\):\\s*([0-9.]+)/"; # get string in Flow field
readSCALE {
extraInput=ignore;
in "%.1/Scale:\s*(.+)\n/"; # get string in Scale field
disconnect; # servers closes, so do we.
#==================< EPICS db file >===========================
record (stringin, "ISAC:WSERV:TITLE")
field (DTYP, "stream")
field (INP, "@regexp.proto readTITLE isacwserv")
record (stringin, "ISAC2:N2ANAL1:PPM")
field (FLNK, "ISAC2:N2ANAL1:FLOW")
field (INP, "@regexp.proto readPPM n2anal1")
record (stringin, "ISAC2:N2ANAL1:FLOW")
field (FLNK, "ISAC2:N2ANAL1:SCALE")
field (INP, "@regexp.proto readFLOW n2anal1")
record (stringin, "ISAC2:N2ANAL1:SCALE")
field (INP, "@regexp.proto readSCALE n2anal1")
#==================< Instrument web page >=======================
# (additional line breaks inserted by e-mail; hopefully this gets
# displayed as HTML text, and not as a web page)
<HTML><HEAD><meta http-equiv="refresh" content="1"></HEAD><BODY
bgcolor="#BEF06E"><!-- Affiche le contenu de l'écran -->
<FONT color="black" size="6"><B><PRE>
<<RUN MODE>> F4:RET
Measure(PPM): 2.3
Sample flow(CC): 50.0 Scale:0-10 PPM
System status:OK </PRE></FONT></B></BODY></HTML>
I am trying to extract the values for 'Measure (PPM)', 'flow(CC)', &
'Scale:'. When the 'FLOW' and 'SCALE' records process, streamDevice reports:
2009/03/04 10:49:59.678 n2anal1 ISAC2:N2ANAL1:PPM: Input "HTTP/1.0 200
OK<0d><0a>Con..." does not match format %.1/^MeasurePM*([0-9.]+)/
2009/03/04 10:49:59.680 n2anal1 ISAC2:N2ANAL1:FLOW: asynError in read:
142.90.132.71:80 connection closed
2009/03/04 10:49:59.680 n2anal1 ISAC2:N2ANAL1:FLOW: I/O error after
reading 0 bytes: ""
2009/03/04 10:49:59.680 n2anal1 ISAC2:N2ANAL1:FLOW: Protocol aborted
2009/03/04 10:50:00.677 timerQueue ISAC2:N2ANAL1:SCALE: I/O error after
reading 0 bytes: ""
2009/03/04 10:50:00.677 timerQueue ISAC2:N2ANAL1:SCALE: Protocol aborted
If I add some more backslashes to the regex in front of the parentheses
that are embedded in the HTML text, the error messages more closely
match the actual HTML text. I can't seem to find a 'right' combination
of back-slashes that makes streamDevice and PCRE happy.
Thanks for any insight.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
- Re: Help with streamDevice parsing HTML Dirk Zimoch
RE: Variable size frame Jeff Hill
Re: Uncovered gold??? - "Channel Access Client Library Tutorial, R3.13" John Faucett
<2009>
2025
2026
New Software Engineer Position at NSCL Eric Berryman
<2009>
2025
2026
