Le mercredi 04 mars 2009 à 11:03 -0700, Jeff Hill a écrit :
> Hello Bruno,
> The maximum array size transmitted is determined by what you service snap in
> returns from casPV :: maxBound ( 0 ). We will call that NS.
I see this but how to pass the payload size (lets call it PS) which
maybe <= NS
> With the current state of the CA protocol the client can request a number of
> elements NE constrained by 0 < NE <= NS. The number of elements NE can be
> specified when making a get, put, or subscription request. As I recall, if
> the number of elements provided by the service snap in is less than what the
> client has requested then the client does not receive status indicating an
> error, and instead it will receive the number of elements it has requested
> with the undefined elements (at the end of the array) being set to zero.
> Note also that if the client subscribes specifying an element count NE then
> that number of elements will not change, but the client always has an option
> of canceling the subscription and starting a new one specifying a different
> NE.
The client can request NE but how does it know PS? I can't see it.
> That’s the current state of things. We will certainly need to consider the
> need for improved flexibility in the future.
I am probably missing a point here because my need sounds pretty common.
I have a CAS server in which I have a PV with a variable data size of
the form (char*, size). I also know its maximum capacity. I expect the
client to be able to read the data an know its size.
I tried first to use a DBR_STRING but I found out it was truncated to 40
chars. Then I tried an array of DBR_CHAR but found no way to pass PS to
the client.
What is the best way to do this currently ?
Bruno.
- RE: Variable size frame Mark Rivers
- Variable size frame Bruno Coudoin
- RE: Variable size frame Jeff Hill
Re: Uncovered gold??? - "Channel Access Client Library Tutorial, R3.13" John Faucett
<2009>
2025
2026
<2009>
2025
2026
