On Tue, Mar 10, 2009 at 10:12 PM, Janet Anderson <[email protected]> wrote:
> You can build at the DOS prompt, you do not need to use sh. Are you using
> GNU make from mingw?
No, not really:
$ make -v
GNU Make 3.81
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i686-pc-msys
It's from MSYS, the mingw version of make may be able to handle the path but
it's too slow on my pc (I don't know why). So I think I should get the mingw
make a chance.
> The cygwin make cannot handle Windows paths with a drive letter. Either one
> of the following
> should work in your RELEASE file:
> EPICS_BASE=D:/EPICS/base
> EPICS_BASE=D:\\EPICS\\base
I can modify the variable but I really hope there's some magic switch that I can
use to output the exact path I entered. Hence, I can make some alias like:
export EPICS_BASE=/epics/base/
alias makeBaseApp="perl
${EPICS_BASE}bin/${EPICS_HOST_ARCH}/makeBaseApp.pl -b ${EPICS_BASE}"
Thank you for your attention.
> Janet
> Zhichu Chen wrote:
>> Hi, there's a silly question: how to disable the path conversion
>> in makeBaseApp?
>> I'm using EPICS under MinGW+MSYS. The "sh" can recognize
>> the DOS path, but somehow it fails in "make".
>> Yes, if I set a path using the DOS version, it just can't find
>> the executable files. I guess maybe the colon symbol is
>> used for some "special" case, so anything like C:\epics
>> will cause unexpected outcomes.
>> Here's the thing, the makeBaseApp.pl will use UnixPath,
>> LocalPath, I don't know, to convert the path and write the
>> base's path to RELEASE, and I always get like
>> EPICS_BASE=D:\EPICS\base
>> even I use "-b \epics\base" option. One thing lead to another,
>> perl could not be found during the make.
>> So, can I use some magic option to make it?
Best Regards
Chen
Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
| www.sinap.ac.cn
- makeBaseApp Zhichu Chen
- Re: makeBaseApp Janet Anderson
Looking for feedback on what epics users require Pawel Kowalski - BiRa Systems Inc.
<2009>
2025
2026
RE: Problem with cothread-1-12 on MacOSX (Leopard) Abbott, MG (Michael)
<2009>
2025
2026
