1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MM4000 asynMotor problem
To: "epics" <[email protected]>
Date: Fri, 13 Mar 2009 11:23:54 +0100
I use MM4000 asynMotor driver to control Newport MM4006 controllers.
The movements are done correctly.
But for certain axis/axes, the DMOV field does not reset to 1 after
position is reached.
I poll the controller status using "MS" command, which reports the axis
is not moving.
Also the MOVN field is going through 0->1->0 sequence correctly.
Other fields when this happens:
MSTA - 0x80a
MIP  - 0x420
>From the MIP field, it is waiting for a Delay callback, which never
comes?
To reset DMOV field, I can write 1 to PROC field or any field any can
process
the record but without moving the motor, e.g. SPMG field.
I am using motor 6-2-2 release for asynMotor device support,
but the MM4000 driver is updated to 6-4-2.
Many thanks.
Dr. Xiaoqiang Wang
Paul Scherrer Institut, WBGB/010
5232 Villigen PSI, Switzerland
RE: MM4000 asynMotor problem Pearson, MR (Matthew)
Prev: Re: Looking for feedback on what epics users require Tim Mooney
Next: RE: MM4000 asynMotor problem Pearson, MR (Matthew)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Difficulty with edm installation Kevin Anderson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
