1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: how to change the MEAN without reboot IOC?
To: Gasper Jansa <[email protected]>
Cc: Michael Abbott <[email protected]>, tech-talk <[email protected]>
Date: Mon, 16 Mar 2009 08:38:35 +0000 (GMT)
On Mon, 16 Mar 2009, Gasper Jansa wrote:
> You can use extended device support to support changes to INP/OUT fields
> in runtime. See chapter 12.5 of Application developer's guide.
Thanks, wasn't aware of this.  Look like that support was added to 3.14.8
(which happens to be the version we've been using for ages...)
Took a little reading to make sense, think I understand it now: is the
idea that every time a write to INP occurs my record will first receive a
del_record() callback follwed by an add_record() callback?
Do I have any idea about the new INP and DTYP values at the time
del_record() is called, or do I have to assume that I'm going to have to
completely detach the record?  I guess the model is that writing to
DTYP/INP are complete changes of record context -- I guess I can work with
that.
Re: how to change the MEAN without reboot IOC? Andrew Johnson
how to change the MEAN without reboot IOC? 汪启胜
Re: how to change the MEAN without reboot IOC? Michael Abbott
Re: how to change the MEAN without reboot IOC? Gasper Jansa
Prev: Re: how to change the MEAN without reboot IOC? Gasper Jansa
Next: Re: how to change the MEAN without reboot IOC? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
