1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Help building EPICS 3.14.9 for RTEMS
To: Sue Witherspoon <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Mon, 16 Mar 2009 13:13:48 -0700
Sue Witherspoon wrote:
I'm trying to build EPICS 3.14.9 for RTEMS-pc386 and I get the following error. It appears that the CONFIG files don't include the cross-compiler include directory. I can't seem to figure out which config file to add the necessary include path. My environment is the following:
EPICS 3.14.9
RTEMS 4.9.1
HOST Linux Red-Hat 4.0 ia32
gcc 4.3.2
Hi Sue.
The following info is IIRC - it's been a while I last
looked into a similar problem:
Have you installed the rtems cross-compiler into
a location different from the install location specified
when building the cross compiler (gcc configure options
--prefix & friends) ?
If so, then the first-choice of builtin search paths for
system headers, executables, libraries, etc.
won't work. Normally, gcc tries
a few alternatives which should work but this
is overridden by EPICS defining (for historical reasons?)
CONFIG.CrossCommon:
export GCC_EXEC_PREFIX = $(GNU_LIB)/gcc-lib/
I say in CONFIG.Common.RTEMS
unexport GCC_EXEC_PREFIX
and relocating my cross-toolchain then works.
For debugging this sort of problems gcc's
-print-<xyz>
options (not literally 'xyz' but the type of info you're
interested in) are your friends -- RTM. Make sure you
try these from an EPICS Makefile so that all other
options and environment variables as defined by
the EPICS build system are in effect.
HTH
-- Till
Any help and clues would be greatly appreciated.
Sue Witherspoon
TJNAF
Accelerator Software Controls
gmake -C O.RTEMS-pc386 -f ../Makefile TOP=../../.. T_A=RTEMS-pc386 install gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.14.9.J1/src/libCom/O.RTEMS-pc386' /usr/csite/pubtools/rtems/4.9.1/bin/i386-rtems4.9-gcc --pipe -B/usr/csite/pubtools/rtems/4.9.1/i386-rtems4.9/pc386/lib/ -specs bsp_specs -qrtems -fasm -c -mtune=i386 -ansi -O2 -g -g -Wall -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/RTEMS -I../../../include ../../../src/libCom/bucketLib/bucketLib.c ../../../src/libCom/bucketLib/bucketLib.c:20:19: error: stdio.h: No such file or directory ../../../src/libCom/bucketLib/bucketLib.c:21:20: error: stdlib.h: No such file or directory ../../../src/libCom/bucketLib/bucketLib.c:22:20: error: string.h: No such file or directory ../../../src/libCom/bucketLib/bucketLib.c:23:20: error: limits.h: No such file or directory ../../../src/libCom/bucketLib/bucketLib.c:24:18: error: math.h: No such file or directory ../../../src/libCom/bucketLib/bucketLib.c:25:18: error: time.h: No such file or directory
In file included from ../../../src/libCom/bucketLib/bucketLib.c:29:
../../../src/libCom/freeList/freeList.h:17:20: error: stddef.h: No such file or directory
../../../src/libCom/freeList/freeList.h:29: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'freeListItemsAvail'
In file included from ../../../src/libCom/bucketLib/bucketLib.c:35:
../../../src/libCom/error/errMdef.h:32:27: error: stdarg.h: No such file or directory
In file included from ../../../src/libCom/error/errMdef.h:42,
../../../src/libCom/error/errlog.h:45: error: expected declaration specifiers or '...' before 'va_list' ../../../src/libCom/error/errlog.h:49: error: expected declaration specifiers or '...' before 'va_list' ../../../src/libCom/error/errlog.h:81: error: expected declaration specifiers or '...' before 'va_list' ../../../src/libCom/bucketLib/bucketLib.c: In function 'bucketUnsignedCompare': ../../../src/libCom/bucketLib/bucketLib.c:184: error: 'NULL' undeclared (first use in this function) ../../../src/libCom/bucketLib/bucketLib.c:184: error: (Each undeclared identifier is reported only once ../../../src/libCom/bucketLib/bucketLib.c:184: error: for each function it appears in.) ../../../src/libCom/bucketLib/bucketLib.c: In function 'bucketPointerCompare': ../../../src/libCom/bucketLib/bucketLib.c:207: error: 'NULL' undeclared (first use in this function) ../../../src/libCom/bucketLib/bucketLib.c: In function 'bucketStringCompare': ../../../src/libCom/bucketLib/bucketLib.c:222: warning: implicit declaration of function 'strcmp'../../../src/libCom/bucketLib/bucketLib.c:229: error: 'NULL' undeclared (first use in this function)
../../../src/libCom/bucketLib/bucketLib.c: In function 'bucketCreate':
../../../src/libCom/bucketLib/bucketLib.c:320: warning: implicit declaration of function 'fprintf' ../../../src/libCom/bucketLib/bucketLib.c:320: warning: incompatible implicit declaration of built-in function 'fprintf' ../../../src/libCom/bucketLib/bucketLib.c:320: error: 'stderr' undeclared (first use in this function) ../../../src/libCom/bucketLib/bucketLib.c:321: error: 'NULL' undeclared (first use in this function) ../../../src/libCom/bucketLib/bucketLib.c:327: error: 'CHAR_BIT' undeclared (first use in this function) ../../../src/libCom/bucketLib/bucketLib.c:345: warning: incompatible implicit declaration of built-in function 'fprintf' ../../../src/libCom/bucketLib/bucketLib.c:355: warning: implicit declaration of function 'calloc'../../../src/libCom/bucketLib/bucketLib.c:355: warning: incompatible implicit declaration of built-in function 'calloc' ../../../src/libCom/bucketLib/bucketLib.c:367: warning: implicit declaration of function 'free' ../../../src/libCom/bucketLib/bucketLib.c:367: warning: incompatible implicit declaration of built-in function 'free'
../../../src/libCom/bucketLib/bucketLib.c: In function 'bucketFree':
../../../src/libCom/bucketLib/bucketLib.c:389: warning: incompatible implicit declaration of built-in function 'free' ../../../src/libCom/bucketLib/bucketLib.c: In function 'bucketLookupAndRemoveItem': ../../../src/libCom/bucketLib/bucketLib.c:474: error: 'NULL' undeclared (first use in this function) ../../../src/libCom/bucketLib/bucketLib.c: In function 'bucketLookupItem': ../../../src/libCom/bucketLib/bucketLib.c:560: error: 'NULL' undeclared (first use in this function)
../../../src/libCom/bucketLib/bucketLib.c: In function 'bucketShow':
../../../src/libCom/bucketLib/bucketLib.c:580: warning: implicit declaration of function 'printf'../../../src/libCom/bucketLib/bucketLib.c:580: warning: incompatible implicit declaration of built-in function 'printf' ../../../src/libCom/bucketLib/bucketLib.c:604: warning: implicit declaration of function 'sqrt' ../../../src/libCom/bucketLib/bucketLib.c:604: warning: incompatible implicit declaration of built-in function 'sqrt'
gmake[3]: *** [bucketLib.o] Error 1
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.14.9.J1/src/libCom/O.RTEMS-pc386'
gmake[2]: *** [install.RTEMS-pc386] Error 2
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.14.9.J1/src/libCom'
gmake[1]: *** [libCom.install] Error 2
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.14.9.J1/src'
gmake: *** [src.install] Error 2
Help building EPICS 3.14.9 for RTEMS Sue Witherspoon
Prev: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Help building EPICS 3.14.9 for RTEMS Sue Witherspoon
Next: Re: Help building EPICS 3.14.9 for RTEMS Eric Norum
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
