1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: weird behaviour of SNL test program running on Soft IOC on LINUX
To: "J. Lewis Muir" <[email protected]>, "Mark Rivers" <[email protected]>
Cc: [email protected], "Stepanov, Sergey" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Mon, 16 Mar 2009 16:43:26 -0500
Hi Lewis,
yes, you are right, adding a pvFlush() function call after each pvPut/pvGet call solves the problem: test program being run on LINUX Soft IOC behaves as expected.
It is strange though that it does not work without explicit pvFlush() calls. If "+a" option is not set for snc compiler, one would expect synchronous IO to be performed.
Oleg
----- Original Message ----- From: "J. Lewis Muir" <[email protected]>
To: "Oleg Makarov" <[email protected]>
Cc: "Mark Rivers" <[email protected]>; "EPICS tech-talk" <[email protected]>; <[email protected]>; "Stepanov, Sergey" <[email protected]>
Sent: Monday, March 16, 2009 3:34 PM
On 3/16/09 4:08 PM, Oleg Makarov wrote:
Hi Mark,
I tried the test with this fix. The problem is not resolved by
epicsThreadSleep code change in the osdThread.c.
CA requests are not being send out  as they arise, some buffering of the
requests occurs to make network communication more efficient. If you
look at the camonitor output, it shows a 3-second period, exactly as
expected.
Are there way to force CA requests to go out as they arise, with no
buffering?
Hi, Oleg.
pvFlush() will flush the SEQ PV layer, but maybe that's not what you're
asking about.
You can also do a synchronous put:
 pvPut(str_cmd, SYNC);
But still, I don't understand why str_rsp would ever contain one of the
commands from str_cmd (e.g. "I522") like your output shows, unless
something is messed up with what's happening in and beyond "{dev}StrCmd"
and "{dev}StrRsp".
Lewis
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Andrew Johnson
weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
RE: weird behaviour of SNL test program running on Soft IOC on LINUX Mark Rivers
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Re: weird behaviour of SNL test program running on Soft IOC on LINUX J. Lewis Muir
Prev: Re: Help building EPICS 3.14.9 for RTEMS Eric Norum
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: weird behaviour of SNL test program running on Soft IOC on LINUX J. Lewis Muir
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
