1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: weird behaviour of SNL test program running on Soft IOC on LINUX
To: [email protected]
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 16 Mar 2009 17:37:06 -0500
Pete and Mark,
thanks for timely response. A tarball might be difficult to produce
because in addition to the soft IOC with SNL, it would also need
some DB in another IOC relating the strcmd strrsp PVs (in our case
they are linked via the PMAC driver sending strcmd content to PMAC
and posting response into strrsp). In any case the problem has been
resolved by adding either pvFlush() or using pvPut(str_cmd, SYNC)
per Lewis' suggestion (thanks Lewis!).
The weird thing is that such actions are not required with the same
code compiled under VxWorks: looks like the VxWorks and Linux
defaults are opposite.
Thanks everyone for help,
-- Sergey and Oleg.
Pete Jemian wrote:
Oleg:
I'd like the tarball as well to test. I see Sergey's Support Request Case HD12639 on this topic.
Pete
J. Lewis Muir wrote:
On 3/16/09 4:08 PM, Oleg Makarov wrote:
Hi Mark,
I tried the test with this fix. The problem is not resolved by
epicsThreadSleep code change in the osdThread.c.
CA requests are not being send out as they arise, some buffering of the
requests occurs to make network communication more efficient. If you
look at the camonitor output, it shows a 3-second period, exactly as
expected.
Are there way to force CA requests to go out as they arise, with no
buffering?
Hi, Oleg.
pvFlush() will flush the SEQ PV layer, but maybe that's not what you're
asking about.
You can also do a synchronous put:
  pvPut(str_cmd, SYNC);
But still, I don't understand why str_rsp would ever contain one of the
commands from str_cmd (e.g. "I522") like your output shows, unless
something is messed up with what's happening in and beyond "{dev}StrCmd"
and "{dev}StrRsp".
Lewis
RE: weird behaviour of SNL test program running on Soft IOC on LINUX Mark Rivers
weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Re: weird behaviour of SNL test program running on Soft IOC on LINUX J. Lewis Muir
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Pete Jemian
Prev: RE: Help building EPICS 3.14.9 for RTEMS Sue Witherspoon
Next: RE: weird behaviour of SNL test program running on Soft IOC on LINUX Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Pete Jemian
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
