BTW:
There was a significant bug
https://www.rtems.org/bugzilla/show_bug.cgi?id=1385
in RTEMS 4.9.1 affecting i386 and m68k
(and maybe others but PPCs using the shared exception framework
[mvme2100, mvme5500, mvme3100, ...] are OK)
you want to upgrade to 4.9.2
-- Till
Sue Witherspoon wrote:
Thanks Eric and Till for the prompt reply. I added
unexport GCC_EXEC_PREFIX in CONFIG_SITE.Common.RTEMS
That works!
until I get to osdInterrupt.c. What's up with rtems_unsigned32?
Thanks in advance,
Sue
/usr/csite/pubtools/rtems/4.9.1/bin/i386-rtems4.9-gcc --pipe
-B/usr/csite/pubtools/rtems/4.9.1/i386-rtems4.9/pc386/lib/ -specs
bsp_specs -qrtems -fasm -c -mtune=i386 -ansi -O2
-g -g -Wall -I. -I.. -I../../../src/libCom/bucketLib
-I../../../src/libCom/ring -I../../../src/libCom/calc
-I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd
-I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
-I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../src/libCom/error -I../../../src/libCom/fdmgr
-I../../../src/libCom/freeList -I../../../src/libCom/gpHash
-I../../../src/libCom/iocsh -I../../../src/libCom/logClient
-I../../../src/libCom/macLib -I../../../src/libCom/misc
-I../../../src/libCom/osi -I../../../src/libCom/taskwd
-I../../../src/libCom/timer -I../../../src/libCom/tsDefs
-I../../../include/os/RTEMS -I../../../include
../../../src/libCom/osi/os/RTEMS/osdInterrupt.c
../../../src/libCom/osi/os/RTEMS/osdInterrupt.c: In function
'InterruptContextMessageDaemon':
../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error:
'rtems_unsigned32' undeclared (first use in this function)
../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: (Each
undeclared identifier is reported only once
../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: for each
function it appears in.)
../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: expected
';' before 'size'
../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:83: error: 'size'
gmake[3]: *** [osdInterrupt.o] Error 1
- RE: Help building EPICS 3.14.9 for RTEMS Sue Witherspoon
Re: Help building EPICS 3.14.9 for RTEMS Till Straumann
答复: how to change the MEAN without reboot IOC? 汪启胜
<2009>
2025
2026
Relational Database Poll Mike Forster
<2009>
2025
2026
