1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ´ð¸´: how to change the MEAN without reboot IOC?
To: Maren Purves <[email protected]>
Cc: [email protected]
Date: Tue, 17 Mar 2009 10:01:52 -0500
Hi Maren,
On Monday 16 March 2009 20:23:51 Maren Purves wrote:
> Can you have several records talk to the same piece of hardware without
> manually disconnecting? (I'm sure it depends on the hardware, but I can
> think of a few where that wouldn't work - and even if you disconnect
> manually, how do you control which record connects the next time?).
Many device support layers work Ok with multiple records pointing to the same
hardware address, although obviously some may have been written without that
in mind and could break if you do that.  I guess the main source of problems
could be asynchronous devices, but in many cases the underlying driver
support is able to handle multiple record types anyway and this generally
requires authors to put the necessary locking and queuing infrastructure into
the support anyway.
Of course having multiple output records driving the same signal could be a
recipe for user confusion if the device doesn't have readback and value
update functionality, so this isn't really recommended.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
how to change the MEAN without reboot IOC? 汪启胜
答复: how to change the MEAN without reboot IOC? 汪启胜
Re: ´ð¸´: how to change the MEAN without reboot IOC? Maren Purves
Prev: RE: Keithley 2000 multimeter support? Elder Matias
Next: Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Keithley 2000 multimeter support? Mark Rivers
Next: RE: how to change the MEAN without reboot IOC? Graham Cross
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
