Can one use the output of a calc or a calcout routine to set values for HIHI, HIGH,
LOW, and LOLO? When I load my database, I always get errors in these lines. Is
there some sort of special incantation that I must do?
Here's what I have. I've used camonitor to check that all of the records leading
up to and including the calc records work as expected. For the calcout routines,
I have a value between 0<= VAL <=1 for ILimMajor and ILimMinor. The calcout
records appear to do what I want them to do:
record(calcout, "$(user):calcQ1I_HiHi") {
field(DESC, "Q1 I Max Major limit")
field(PREC, "3")
field(INPA, "$(user):Q1SetCurrent.VAL NPP NMS")
field(INPB, "$(user):ILimMajor.VAL NPP NMS")
field(CALC, "A+(A*B)")
record(calcout, "$(user):calcQ1I_High") {
field(DESC, "Q1 I Max Minor limit")
field(PREC, "3")
field(INPB, "$(user):ILimMinor.VAL NPP NMS")
field(CALC, "A+A*B")
record(calcout, "$(user):calcQ1I_Low") {
field(DESC, "Q1 I Min Minor limit")
field(PREC, "3")
field(CALC, "A-A*B")
record(calcout, "$(user):calcQ1I_LoLo") {
field(DESC, "Q1 I Min Major limit")
field(PREC, "3")
record(ai, "$(user):Q1ReadCurrent") {
field(DESC, "Q1 Magnet Readback Current")
field(PREC, "3")
field(INP, "$(user):rampQ1Current.VAL NPP NMS")
field(EGUF, "10")
field(EGU, "A")
field(HOPR, "2000")
field(LOPR, "0")
field(HIHI, "$(user):calcQ1I_HiHi.VAL")
field(HIGH, "$(user):calcQ1I_High.VAL")
field(LOW, "$(user):calcQ1I_Low.VAL")
field(LOLO, "$(user):calcQ1I_LoLo.VAL")
field(HHSV, "MAJOR")
field(HSV, "MINOR")
field(LSV, "MINOR")
field(LLSV, "MAJOR")
field(FLNK, "$(user):Q1RampCurrent.PROC")
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
- RE: Alarm Limits Owens, PH (Peter)
- RE: Alarm Limits Mark Rivers
Re: epics GUIs (update) Noboru Yamamoto
Re: Starting multiple SNL programs Martin L. Smith
<2009>
2025
2026
Re: RTEMS-mvme5500 BSP update Kate Feng
<2009>
2025
2026
