1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epics GUIs (update)
To: "'Wang Xiaoqiang'" <[email protected]>, "'epics'" <[email protected]>
Date: Fri, 20 Mar 2009 09:51:12 +0900
This is Sulhee Baek from National Fusion Research Institute (NFRI), Korea.
I have developed the widget toolkit which is a collection of the Qt widgets to be able to communicate with EPICS.
It consists of Qt-CA interface and 16 widgets which were developed to satisfy our requirements.
It uses Qt library and some of it depends on Qt Widgets for Technical Applications (QWT) library also.
In order to develop new operator panel, drag the proper widget from the widget box at the left and drop it to the wanted position.
And modify widget’s properties including pvname, geometry size, color, font, etc. at the right.
I focused on helping developers to work fast and it’s result to be fancy using Qt library.
The widget toolkit was used to develop OPIs for the KSTAR commissioning.
Sulhee Baek
Sulhee Baek
Integrated Control Team
Tokamak Operation Division
Gwahangno 113, Yuseong-gu, Daejeon, 305-333, KOREA
Tel  : +82-42-870-1632
Cell.: +82-11-9805-9958
Fax :  +82-42-870-1609
e-mail : [email protected]
Re: epics GUIs (update) Noboru Yamamoto
Prev: Re: RTEMS-mvme5500 BSP update Joel Sherrill
Next: Re: epics GUIs (update) Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics GUIs (update) Mauro Giacchini
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
