1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fonts for Probe under Scientific Linux
Date: Tue, 24 Mar 2009 16:00:36 -0400
> Hi all,
> I have installed "probe" unter Linux and OpenMotif. When probe starts, the messages
> Unable to load font!
> Unable to load font1!
> Unable to load font2!
> shows up. It needs some "-adobe-*****-iso8859-1" fonts (seen in probe_main.c). Probe is usable but the characters are quite small and hard to read.
> "xlsfonts" displays only a few fixed fonts. If I use YamExtender and search for installed font packages, I find a lot.
> How can I install the necessary fonts, so that they can be used?
You don't mention what version of Scientific Linux you're trying to use.  I wonder if the root cause could be the removal of the X Font Server, like it is with edm and recent (> 7) versions of Fedora?  http://www.aps.anl.gov/epics/tech-talk/2009/msg00393.php has more details with how to get around that problem.
Otherwise, try downloading xorg-x11-fonts-75dpi and xorg-x11-fonts-100dpi.  You might also be able to get a better idea of what fonts you have available using xfontsel instead of xlsfonts.
-Kevin
Re: Fonts for Probe under Scientific Linux Bernd Schoeneburg
Prev: Re: Fonts for Probe under Scientific Linux Matthieu Bec
Next: Re: synApps 5.4 release Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Fonts for Probe under Scientific Linux Bernd Schoeneburg
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
