1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Smoothing and alarm filtering on the analog input record - a proposal
To: "Dalesio, Leo" <[email protected]>
Cc: [email protected]
Date: Tue, 31 Mar 2009 09:35:27 +0200
Hi Bob,
Dalesio, Leo wrote:
DESY would like to see the following changes:
SMOO applies to all values returned from device support - weather or not they need to be converted. This should have no impact - as device support that returns engineering numbers likely does not have SMOO set to anything. Same thing for returning values from database links that are inputs. Any objections?
I think that would break device supports that emulate the SMOO behavior when returning numbers in engineering units. I have written a few of them.
Add the following fields
TOUT - timeout before raising an INVALID/TIMEOUT alarm when the record has not been processed (esp. in Passive or I/O Intr scanning mode).
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Smoothing and alarm filtering on the analog input record - a proposal Dalesio, Leo
Prev: connections with pasynOctetSyncIO->connect John Hammonds
Next: RE: connections with pasynOctetSyncIO->connect Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Smoothing and alarm filtering on the analog input record - a proposal Kasemir, Kay
Next: connections with pasynOctetSyncIO->connect John Hammonds
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
