Mark,
This connection is set up with the following commands:
drvAsynIPPortConfigure("usaxsEns","164.54.102.16:8000",0,0,0)
asynOctetSetInputEos("usaxsEns",0,"\n")
asynOctetSetOutputEos("usaxsEns",0,"\n")
asynSetTraceMask("usaxsEns",0,0x9)
asynSetTraceIOMask("usaxsEns",0,0x2)
I only see evidence of the first try for this send that tests
communications. There should be 3 retries. After the first try we get
the message:
164.54.102.16:8000 write error: S_errno_EPIPE
We then get the message that seems to come from pasynUser->errorMessage
on subsequent retries.
I can go to an asynOctet MEDM screen and send some messages. The trace
on these reflects the send/recieve of messages. I have to send a couple
of messages to get the connect but communications can be a bit spotty
(sometimes need retries).
I can also add the following to the st.cmd and see reasonable
communications coming through:
asynOctetConnect("myID", "usaxsEns", 0, "\n", "\n", 80, 20)
asynOctetWriteRead("myID", "NONE")
asynOctetWriteRead("myID", "GETPARM(CONTROL, 265)")
asynOctetWriteRead("myID", "GETPARM(@0, 257")
asynOctetWriteRead("myID", "AXISSTATUS(@0)")
This seems much more reliable than the using the asynRecord Interface.
I took this from an example on
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-10/asynDriver.html.
Note however that the documentation for asynOctetConnect does not appear
to match the example.
John
Mark Rivers wrote:
John,
I think that if it returns asynSuccess you should ignore the error message, because it may be stale.
What do you see if you turn on asynTrace and do some writes? Does the driver claim to be writing? What type of communication port is this?
Sent: Mon 3/30/2009 11:21 PM
To: Tech Tech Talk
Subject: connections with pasynOctetSyncIO->connect
What checks should be done to verify a connection with
pasynOctetSyncIO->connect? I have a driver that calls this. The return
value is asynSuccess but the pasynUser->errorMessage is "port usaxsEns
or addr -1 not connected" and we see no communication.
John
John Hammonds
Beamline Controls and Data Acquisition Group
APS Engineering Support Division
Argonne National Laboratory
[email protected] <mailto:[email protected]>
(630)252-5317
John Hammonds
(630)252-5317
- Re: connections with pasynOctetSyncIO->connect John Hammonds
- connections with pasynOctetSyncIO->connect John Hammonds
- RE: connections with pasynOctetSyncIO->connect Mark Rivers
EPICS Meeting Vancouver Rolf Keitel
addMonitor memory leak in JCA Kasemir, Kay
<2009>
2025
2026
<2009>
2025
2026
