1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Motor Soft Record Client Interface
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Apr 2009 12:00:37 -0700
So I guess then the answer is that we just have to tell the controls engineers at the various synchrotrons that these are the outputs that we are expecting when we are attempting to address energy as though it were a motor axis.
Thanks.
-Richard
-----Original Message-----
Sent: Friday, April 03, 2009 11:45 AM
To: Richard Pastrick; [email protected]
If you are addressing a motor that uses the EPICS motor record that is part of synApps, then there is a perfectly well defined set of fields available.  If you are addressing a motor that does not use the motor record then things are more difficult.  There is a database used by the GMCA and others for the Delta Tau motors, so that is another "standard".
But when you say:
>It doesn't matter if it is energy or whatever. My question is more towards motor records in general.
It actually does matter.  Typically energy is NOT a "motor record", it is another type of record (e.g. ao) and cannot be addressed using the fields for a motor record senso stricto.
Sent: Fri 4/3/2009 1:37 PM
To: Mark Rivers; [email protected]
It doesn't matter if it is energy or whatever. My question is more towards motor records in general. If I am expecting to be addressing a motor, is there a minimum set of fields that I should always expect to be implemented?
-Richard
Sent: Friday, April 03, 2009 10:57 AM
Energy is usually not actually a "soft motor" per se (e.g. motor record), but another type of PV.  There is no standard being used.
From: [email protected] on behalf of Richard Pastrick
Sent: Fri 4/3/2009 12:20 PM
To: [email protected]
Subject: Motor Soft Record Client Interface
I have implemented a client interface for EPICS motors on windows for an x-ray microscope and one of the key features was the ability to integrate with various soft motor records which control the energy axis at synchrotrons. I was wondering if there was a list of required fields that I could depend on to be implemented at each site or am I partially at the mercy of the controls engineers?
Thanks.
Richard Pastrick
Associate Software Engineer
Xradia Inc
5052 Commercial Cir
Concord CA 94520
925-288-1228 Ext 1151
925-771-8051 (direct line)
925-348-0384 (cell)
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
Motor Soft Record Client Interface Richard Pastrick
RE: Motor Soft Record Client Interface Mark Rivers
RE: Motor Soft Record Client Interface Richard Pastrick
Prev: Re: Motor Soft Record Client Interface J. Lewis Muir
Next: Re: Motor Soft Record Client Interface Peter Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Motor Soft Record Client Interface Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
