That looks like libxerces-c.so.24 cannot solve some of its dependencies. Try
ldd /usr/local/lib/libxerces-c.so.24
and see if something is missing. I get:
libpthread.so.0 => /lib/tls/libpthread.so.0 (0x00111000)
libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x0099e000)
libm.so.6 => /lib/tls/libm.so.6 (0x0082a000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x008ec000)
libc.so.6 => /lib/tls/libc.so.6 (0x00121000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x00ec2000)
Maybe you have other versions of libstdc++ or libc.so on the machine you run it
than on the machine libxerces-c.so.24 was compiled?
Dirk
zhangdemin99 wrote:
Dear all,
I have successfully installed Channel Archiver and base3.14.9-pre1 on
Red Hat Linux WS4 . But ther are following error when I run
"ArchiveEngine" :
$ArchiverEngine
$ArchiveEngine:error while loading shared
libraries:libxerces-c.so.24:can't open shared object file:No such file
or directory
While the file "libxerces-c.so.24" in /usr/local/lib, I rebuild the
Channel Archiver setting
LD_LIBRARY_PATH=/usr/local/lib:/home/fel/psm6003/extensions/lib/linux-x86
but it comes the same erro.
Best regards,
Demin Zhang
网易邮箱,中国第一大电子邮件服务商 <http://email.163.com>
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- problem when running Channel Archiver zhangdemin99
Re: longout record issue Andrew Johnson
<2009>
2025
2026
gensub constant char input parameter Emmanuel Mayssat
<2009>
2025
2026
