1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building problem with the latest cvs
Cc: [email protected]
Date: Fri, 10 Apr 2009 07:21:19 +0800
On Fri, Apr 10, 2009 at 2:01 AM, Andrew Johnson <[email protected]> wrote:
> On Thursday 09 April 2009 12:29:21 Zhichu Chen wrote:
>> I just downloaded the latest base_R3-14_cvs.tar.gz and tried
>> to compile it under MSYS, MinGW, WinXP. Anyway, error
> I happen to be working on fixing these problems right now, we checked in quite
> a few changes at the EPICS Codeathon last week which weren't tested on
> Windows.
> Is there some particular reason why you need to use the CVS snapshot (which we
> warn is subject to these kinds of issues) rather than the last official
> release R3.14.10?
No, I was trying to test it rather than to use it. I just hope I can
help you to get
the code working better on every platform or using any compilers, I mean, make
sure the next official releases will get better even though the latest
release is
good enough. I thought you guys needed a bunch of people to test those snapshots
before making a stable version.
> - Andrew
> The best FOSS code is written to be read by other humans -- Harold Welte
Best Regards
Chen
          Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
         No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
             tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
                                               | www.sinap.ac.cn
Re: building problem with the latest cvs Andrew Johnson
building problem with the latest cvs Zhichu Chen
Prev: Re: building problem with the latest cvs Andrew Johnson
Next: Re: building problem with the latest cvs Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
