In the CAS server, vector variable are always sent at their maxBound
size instead of their real size as found in the user's provided gdd.
This has 2 consequences:
- We loose bandwidth transferring trailing zeros when the vector is not
fully populated.
- On the client side, there is no way to determine where the data
stops in the vector.
Digging in the code I found out that in
casStrmClient::readNotifyResponse the message size is based on
msg.m_count which is set to maxBound. Don't desc.getDataSizeElements()
should be used instead.
Am I doing something wrong or this is a bug ?
Bruno Coudoin
http://gcompris.net Free educational software for kids
Re: record processing delay Andrew Johnson
ca_put with non base type Bruno Coudoin
<2009>
2025
2026
Re: record processing delay jun-ichi.odagiri
RE: CAS server and partial vectors Bruno Coudoin
<2009>
2025
2026
